You said early on that you had a sump breather running to the cam covers!!?
I have no head drain and two 1.0mm restrictors. I have drilled and tapped two holes as high as possible in the sump forward of the dip stick and run one hose to the top of the catch can and one to the bottom for a drain (might stick a one way valve in it as some have suggested). I now get no oil coming out of the cam cover vents. The oil which was being pushed out at extended WOT (this is on an RB30/25) was going nicely back down the drain. On my last outing I got some oil coming out of the catch can breather after a few laps probably because I have overdone the overfilling trick (poss 7L or even more) so I will reduce it to 6L and I expect it will be fine.
Yeah the sump to cam cover vent was intended to reduce the work for oil drains.. I will probably now feed it to catch can
  • 1 month later...
Any news on this? Ive currently got a T piece in drivers side rocker cover that links sump----->rocker cover-----> catch can. Require a check valve?
I have solved my spewing out oil problems as above.
I have not relieved/drilled out the oil returns because I don't want to pull the engine out and strip down the motor to clean the block afterwards but it seems a good move if you are at the building stage.
What I have (RB30/25 with VCT and an N1 pump):
2x1.0mm restrictors
2 x 1/2in holes drilled and tapped as high as possible driver's side of sump - one hose leads to the top of a catch can the other to the bottom for a return (don't have a non-return valve in it but that seems a good idea and I may do that) . There is pretty much nothing coming out of my cam cover breathers now and I have them T'eed and going in to the catch can.
This has enabled me to do two full track days without covering my engine in oil and exiting in a cloud of smoke. There is some oily mist coming from the breather on the catch can but I have a plan to deal with that.
I have another catch can and will run the breather from the first into it as well as the cam cover breathers, and baffle it to try to seperate out the small amount of oil that comes through. I will vent this second can to the turbo intake.
Breathers from the sump to the cam covers are not a good idea and the "head drain" at the back of the head is not really usefull for anything.
I got a one way valve, havent sorted this yet, in that iv done nothing about it having been street driving only and no track work for a while. I plan to get it happening asap
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
