Here is my pride and joy for expressing of interest at this moment. 1993 model in Burgundy colour.
KMs: 113000kms.
Mods:
2860-5 turbos
Walbro fuel pump
Nismo 600cc injectors
splitfire coilpacks
HKS camgears
grex oil cooler
Trust oil sump.
tomei oil restrictors
Power FC with hand controller
HKS boost controller
Extreme twin plate clutch
Original Nismo seats in perfect condition.
Alloy radiator.
Custom made oil catch can by Silverwater Automotive
Carbon shielded airbox
Nismo N1 headlights with HID kit installed.
Brand new Optima AGM dry cell battery with 800cca just put in.
HPI clear timing belt cover.
Braided water and oil lines on turbos.
Atezza switch between AWD and RWD
The bad:
Dash light is on and off which might be bad connection behind. I haven't really had time to take it out to check.
No A/C, condensor was taken out to fit the large oil cooler.
The car is in very good condition for an r32. Not a single bit of rust underbody, in the boot or in the engine bay, or even on any panels. Interior wise, a little wear and tear on steering wheel and shift boot. Dash condition is immaculate with absolutely no bubbles on the passenger side. Car is dead straight and drives dead straight.
Power: 330awkw @ 21psi on high boost
309awkw @ 19psi on low boost
Note: Power made with gtr AFMs. But they are at their max so Z32 AFMs are the option for more power out of this setup.
No asking price as this is a pure EOI. Offers are welcome.
Photos:
Photos:
Edited by G0Z1LLAAAAA34
https://www.sau.com.au/forums/topic/409736-syd-1993-r32-gtr-~eoi~/
Opps forgot to add:
Genuine Bilstein coilovers
Nismo front pipes followed by 3 inch cat back
Large 2 piece front brake rotors (Brand unknown, they came with the car when I bought it)
More technical bit:
Knock: 25-35 shown on FC hand controller on high boost setting
Injector max duty: 68-70% under full power on high boost setting
oops, you also forgot to add the price
read the rules
I don't know if you understand what express of interest means......This isn't an official for sale add so no price needed in the thread.
He is asking $16500 on JDMST.
And I don't know which GTR you are referring to. Read my jdmst thread again and see if there is a price on it....
Did you tell him he's dreaming?
I don't know what dreams you are having but i am certainly awake if you haven't noticed :)
No money owing. No major accidents. The chassis is accident free. I think a couple of panels have been repainted before I purchased the car as we can expect from a r32 gtr this age.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
