Hi,
STANDARD FUEL CAPS. I don't think mine is the right one. Even though it says Nissan on it, it doesn't seem to keep pressure in the tank at all.
I have determined this from not hearing any 'pshhhhhhhhhh..' sound when I undo the cap. I swapped over the cap with my mum's S13 Silvia, and still no 'built-up-pressure' sound at the petrol station.
Also, if the conditions are 'right', I can see that hazy petrol 'vapour' pouring from the fuel flap, and sometimes the smell inside the cabin is quite bad, (girlfriend hates it...I do too). I am wondering if this could be causing the smell inside my car. All else looks OK, no leaks..etc. Cars performance seems ok (seems!!!).
I know the car has been involved in a 'rear' accident in Japan. (How bad? ...Don't know)
Is there an 'identifier' on the cap that clearly states it to be R33 specific?
Thanks,
Mark.
  • Replies 46
please keep responses coming....I need a definate answer for this one...I'm loosing brain cells thru the fumes!! I'm sure it's got something to do with the cap, and maybe 'blow-back'.
thanx!!
mine is the same, the r33 cap on my car has holes on it if you detatch the cap part from the screw in part...(lol hard to explain) There are holes in the screw in part which i imagine vent out pressure, why I dont know, you can buy new ones from workshops or websites though and im sure it will fix your problem.
Jimbo seems to have the right noise... I know my cap works on the S13 Silvia, but not the other way around. (by working I actually mean making the pressure noise on unscrewing)
Surely there must be some consistancy here?
Thanx 33NIZ,
Mark
thanx!!
All Nissan fuel caps are (should?) be the same. Hence you can buy a "Nismo" branded fuel cap and it will fit on any Nissan.
This also makes mass production of the part cheaper which makes sense.
My cap does not make a pressure release type noise and I do not smell any fuel vapour inside the car.
Thanx SEWID...
Production technique Seems Logical, inconsistency in other's standard fuel cap's isn't.
Ta.
it's not the actual plastic cap, but the hunk of metal the cap srews into, was not sealed when it was changed over at compliance...
u have to get one the right size, and then seal it somehow... dont use silicone though.
AH HAH!!!..........now that u mention it Z, my filler spout does look new (and dodgy) and aftermarket.
..........mmmmmmmmmmmm
WOT 2 DO ???????
Thanx sooo much Zahos!!
Keep em coming in everyone!!!!!!!!! this is interesting stuff...starting to make sense a little....
OK well I think i have the answer. My car leaks out vapour and does no have the schweppes pshhhhhh sound. But I looked at my mates cap which works properly and the difference was a real thin rubber ring which I remember taking off the fuel cap cause it had already half fallen off when i first bought the car.
thanx CR33
Do u think that pressure, or lack there of, can create performance problems in the fuel delivery department, or compromise safety at all?
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
