my car makes the consistent pshhh sound every time i open it. and yep they do change and tap on a new nozzel in compliancing. when i picked up my car i had this wierd metal thing sitting in the cup holder....looked like a funky jap tea cup..haha. anyways i had to go to the engineer to sign some papers and he was shocked to see that it wasnt fitted when i asked him what it was. he then proceeded to pull out this big cork screw thingy and tap it into the existing nozzel right there and then....signed the papers and i was off:D:D
  • Replies 46
Special Glue Used DAN ?
Use a product called "Sikaflex" to re-affix the metal threaded part onto the car.
Put a lot on around the metal threaded part, so when you press the metal threaded part onto the car, the black Sikaflex oozes out around the sides.
Leave it for 24 hours to dry, and then cut the excess black Sikaflex away.
Done.
As far as I can tell, the PSSSSSSHHH noise is air getting sucked into the fuel tank. Because as your fuel pump lifts the fuel away into the motor, it isn't injecting any more air into the tank (it's completely sealed)... So as it lifts petrol away, it creates a vacuum in the tank, so when you open the fuel cap, air rushes in to fill that negative pressure area.
If you don't get the PSSSSSHHHHH, your fuel tank isn't completely sealed.
This problem can easily be solved. You see, as part of the compliance process, the whole fuel intake pipe (including the cap) is supposed to be changed so that it becomes compatible with Aussie pump nozzles. There's quite a few of these workshops that do dodgy jobs in modifying these things. I'm pretty sure your intake pipe is cracked or has a hole thus the fuel tank could not hold pressure. Take this out and have a better one made or get it sealed properly. You will eventually get the Pshhhhhhh sound once this pipe is sealed.
We should ask some of the Japanese R33 owners what happens when they open the fuel cap.
Thanx Sewid, practical advice.
I did not realise how popular this thread would become, thanx everyone!!
good thread!
i have this problem too....(hazy vapour being emitted)
I had a look at the spout....its a little wobbly. Also checked the shed and i have some automotive sikaflex.
just wondering how you get the spout out? theres like a giant rubber seal surrounding it. Does that come off and then expose the sealing face of the spout?
Our do i have to get in under the car to get the spout out to get some sikalex in and around the join?
i hnfi lol
So TOBY, whether it is a pos or neg pressure (Merli suggests a negative pressure) ,in the tank at any time, as i take it there is supposed to be, hence the tight fitting cap (plus anti spill),
......would no pressure at all be bad for the fuel delivery system. Or my brain cells..(da ones I got left) in the way of fumes?
good thread!
i hnfi lol
Man........if you find that out, we'll both be happy!!
wish I knew more about 'sikaflex' and if it's actually good sh1t !
yeah i'll have a play around with it tomorrow and see what i can acheive.
Sikaflex is excellent....a dedicated automotive sealant (you can get household varieties as well so check the tubes) can get them from ordinary car places that sell sealants. i think you can get a tube of it (for a caulking gun) for around $14....
http://www.sikaautomotive.com/ind-auto/aut...roduct-flex.htm
if you want to know more about it
  • 4 months later...
Sorry to dig this thread up again...
But i seem to be having a problem with my fuel staying IN the tank :S
When i have more then 3/4 full of fuel, and take hard left turns, i get dribbles of fuel down the side of my car :rolleyes:
Never use to do this, i also get no "pressure" sound, and a LARGE amount of vapour pouring out
Looks pretty, but yeah...
Change caps? Change filling nozzel/neck?
*shrugs*
I used to have this problem, I even changed the fuel cap and it still did it. What worked for me was I put an extra rubber o ring on the cap and the problem was gone, by the way i never had the noise even when it was fine, pretty sure they have a pin hole breather in the cap.
  • 5 weeks later...
Mum can't drift, the car can though,.... when my L plater little bruvver drives it.
Mum Loves it!!!!
Man If you get this problem fixed, let me know how you did it??? I have the exact same problem, except I might be used to the cabin fumes. I wonder if this could be a partial cause to bad fuel economy???
  • 3 weeks later...
GZ - where did you get an extra o-ring from?
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
