I have noticed a couple of threads that have popped up recently discussing the transgo shift kit
Given that I have just got back into doing track days after a break for the last year and a half I am seriously considering getting one of these as everyone raves about how much of an improvement they make when it comes to shift times particularly when using triptronic.
I'm pretty sure I can shave a bit more off my lap times if the auto box changed faster. I have started to play with the triptronic around a couple of corners/hairpin where the box cant make its mind up if it wants to be in 2nd or 3rd gear but the lag in the changes makes this kind of futile
I'm on the Gold Coast and would be willing to drive to Brisbane to get this done
I've noticed a couple members who do installs but it seems they are based in Melb/Syd
Any advice or anyone know where I can go to get one supplied and fitted in QLD?
Also on a side note has anyone upgraded their brake lines who has actually done track days before and after getting them fitted?
I've decided for the moment that I'm going to stick it out with the poverty spec non brembos as the QFM A1RM pads seem to be working well enough for a street/track pad. I have however noticed that my brake pedal gets pretty spongy once the brakes heat up at the track
Its probably been 2 years since I had the fluid changed “dot 5.1” so a full flush of the system +new fluid should help somewhat
I just keep reading mixed reports about weather they actually do work see the link below
http://autospeed.com/cms/title_Braided-Brake-Lines/A_2679/article.html
I think he does it for $250 but you would have to PM him. That price would be with you supplying all the Nissan Matic J or Nulon synthetic trans fluids.
For anyone in Melbourne, I can install it for the same price and supply the kit from Jetwreck.
I ran my stock auto brakes here out on the track at Mallala ONCE, and NEVER AGAIN - I went out and bought some Brembos and 2 piece floating rotors. After 2 half decent laps my pedal went to the floor and was seriously scary. Admittedly that was with stock pads and fluids, but dayum it was scary!
I uprgraded my brake lines to Goodyear braided and lines and seriously didn't notice any difference. But for the price it is VERY cheap insurance, so would still recommend.
I went for a spin in Sam's V35 with the transgo kit, and HIGHLY recommend it. Changes were SIGNIFICANTLY faster, and made the car feel completely different! It is next on my mods list.
I would love a set of Brembos and was looking into the idea a year or so back, problem was I could not find a set at a decent price, just had a look and found these http://www.ebay.com.au/itm/Nissan-V35-Skyline-Brembo-Brake-Calipers-Set-4-Front-Rear-Parts-Wrecking-/290767489551?pt=AU_Car_Parts_Accessories&hash=item43b317ca0f#ht_1061wt_1397
Still asking a bit much
What did you end up paying for yours?
That is not a bad deal - I have seen them advertised for over $3k.
I got VERY lucky - I bought them off USA Ebay, and shipped the via a drop-shipping company (www.comgateway.com) ..... mine were just over $2k delivered including near new Project MU pads and 2 piece Stoptech floating rotors. I think I got buy of the century though.
I was looking into getting a pair of brembos too, but may as well get the brand new akebonos from czp instead of used brembos, heard quite a lot of good things about them too
I had SS brake lines on my old Maxima which I used to track now and then. Zero difference between them and the OEM rubber lines. The theory is sound and there would definitely be some swelling taking a little bit of the pressure away from the calipers but the pressure difference was (measurably) minute.
Instead, what you're experiencing is the fluid getting hygroscopic at the higher temperatures so you need to use something better. A full flush and replacement of the fluid is a step in the right direction but you need to find one that will operate at temperatures typical of track racing if you want to keep that sponge pedal away.
Only if they not ADR approved. You can get ADR ones. It's still rubber under the braided SS.
There has been quite a few cases of the braided line popping/ leaking. I wouldn't bother.
Transgo ftw.
Aren't SS lines illegal?
Only if the tubing itself is Teflon. Supposedly, given Teflon's greater rigidity, it is more prone to fracturing and leaking than rubber so it's not really well suited to components which are in constant motion across the X and Y axes, as is the case with your wheels given the suspension moves them up and down while the steering moves them left and right.
It was never a problem on the Maxima but it was of zero benefit too.
Thanks for your input guys, I'll pass on the braided lines and just get the fluid flushed. Its been close to 2 years since I had it flushed/changed using Dot 5.1 so I'm sure its overdue for a flush/change
Anyone have any recommendations for getting the transgo kit installed in Brisbane/Gold Coast?
If not a couple of mates have had their auto commowhore gearboxes rebuilt by a local shop on the Gold Coast and have said nothing but good things so I might end up giving them a call to see if they have experience/how much they want to install the kit
I messaged Jetwreck but haven't got any reply yet about the current going rate on buying a kit. I'm sure he has read the message might just take a few days to get around to me. Otherwise if its just a straight purchase of Ebay from the US I can always just go and do that myself.
I've had a look already and cant believe the difference between getting one straight from the US vs Australia
Option one is to get raped by these guys in sydney http://www.ebay.com.au/itm/TransGo-Stage-2-Shift-Kit-RE5R05A-Auto-Transmission-/350313868972?pt=AU_Car_Parts_Accessories&hash=item5190556eac#ht_2854wt_906 who want $633.50 inc postage
Or I could buy if from these guys in the US http://www.ebay.com.au/itm/TITAN-ARMADA-RE5R05A-NISSAN-AUTOMATIC-5-SPD-H-D-HI-PERF-REPROGRAMMER-RWD-4WD-/330741151970?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d01b578e2#ht_2199wt_1163 for around $296 inc postage with the dollars current rate at the time I post this
As someone who works in retail I'm all about buying things from the local guy to keep jobs/money in the country but at double the price and then some the local guy can go suck a big one
That's a good price (Ebay), but check out Summit Racing (http://www.summitracing.com/search/?keyword=transgo%20RE5R05A&dds=1) as most guys who didn't buy their kit from Jetwreck got it there. It was fast shipping too.
Craig will respond soon I'm sure. IMO it's a better deal to send the valve body to him (dead easy job removing & refitting) as it will be done right. Even so called experts can get these things wrong, or they take a long time so cost more, unless they've one recently. I'd get a FIRM quote before going ahead.
The upside of getting a local to do the work is it will be quicker (it's the return shipping that costs a few days) & less messy, but if you can have the car off the road for a short time then save some cash & send it to Jetwreck.
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25 The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
