After what feels like a lifetime my gtr is nearing completion.
attached are pics of the build.post-26806-0-93711300-1348147246_thumb.jpgpost-26806-0-30433000-1348147305_thumb.jpg
rwkw exceeded 330kw at 12 pound of boost with recent dyno tune however Throttle position sensor was faulty and dyno tune subsequently aborted. I managed to find the only new tps switch in aus and she's back on the dyno tommorrow and we should no doubt see more than 400 at the wheels on modest boost. it had 280kw at 9 pounds
It seems every sensor this car had has gone faulty, i have now had to replace, 02 sensor, all the wheel sensors and im now up to my third cam sensor(brand newy on the way)
I 'm no expert and whilst i have had many doubts over the direction the build was going over all this time,
the team at JPC (johnsons performance centre) have truly exceeded all my expectations with the final product.
I chose JPC because i have know them since i was 18 (i'm 36 now) and rememeber there cars been big news at the drag strip.
They've always struck as very switched on and knowledgeable and most of all, you never feel they are taking advantage of you.
Initially i did everything i could to gather parts and reduce the cost however everything i bought was ditched by JPC for something
bigger/stronger/hardier and obviously better on sight alone, hence i eventually stopped throwing my two cents in and went with everything they said.
Some of you may recognise the engine covers appearing an engine that was newly built and for sale on this forum several years ago, i was silly enough to pay upwards of 7k and buy that supposedly properly built engine. all that remains of that engine are the worlds most expensive timing gears and rocker covers, i had hoped all i would need to do was change cams and stick my sump on it - yeah right......
anyway car now sports the following:
rb30 block (not o ringed)
cp pistons and rings (NOT CHROME MOLLY)
custom cams
race ported head
custom split pulse exhaust manifold
Hypertune plenum (maintaining 6 throttle body set-up)
JPC modified Garret TO4z
Vipec v88
M&w ignition system
Bosch 1000 cc injectors
N1 oil pump with JPC's billet gears(this stops it breaking like everyone else's)
JPC modified Hi-octane sump
HKS fuel rail
Garret 100mm intercooler
race radiators radiator and thermo fan
PPG dog box
os giken triple plate clutch
Quaife ATB front diff
Battery now sits where left hand rear passenger once sat and there is a custom aluminium fuel tank in the boot. Used to be small but the guys welded on another section to make it more than 60litres and incorporated the surge tank into th bottom of it.
Suspension is Bilstein, with various whitleline and cusco control arms etc
front Upper contral arms are the "pivoting" UAS(unique auto sports) adjustable ones - might mate hearney reckons he'll never leave for a track day without them again.
Brakes are AP 6 pots with Strap drive rotors at the front and Ap four pots at the rear. Abs and brake booster have been removed
and Race brakes has reconfigured the braking system and fitted a balance bar.
The guys at JPC, having worked with rb's since the 80's have obviously experienced oil control issues on RB's more than anyone.
in this regards they seem to have taken no chances with the oil breather system/catch can set up. I think i counted about 5 tanks, it is also plumbed back to the sump and a set of Mine's baffles sit inside the rocker covers. (i would hope that should cover it).
The factory loom has pretty much gone, what you seen was compiled by Al at Jpc. he seperated the attessa part and pretty much dumped everything else and made up a new loom from scratch to run the vipec/engine/lights. the Attessa part will be pretty much gone soon also but more on that later
car is pretty much stock on the outside, i did buy all the window moulds brand new from nissan, including a set of rear quarter windows. I dont think i need to tell people how much this car has cost, you can probably figure it out yourselves, hence may as well make it look worthy of the cost, i hate ratty moulds/garnishes.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
