Hey guys,
Ive decided to sell my well looked after R32 GTS-T, is in great condition.
  • Has 144XXX kms on clock!!
  • Serviced at every 5000kms.
  • Manual Transmission.
  • RB20DET.
  • Only Every filled up with BP ULTIMATE.
  • Gunmetal Grey paint, with Legit black GTR Bonnet and GTR grill.
  • GTR front bar (aftermarket)
  • GTR V-Spec II Boot (legit), with lip and wing.
  • Front mount intercooler.
  • Op6 R34 GTT Turbo.
  • Full 3" Turbo back exhaust with Hi-flow Cat.
  • Nistune.
  • GFB Boost Controller.
  • Very dark tinted windows.
  • Bilstein Shocks.
  • King springs.
  • Aircon & heater works perfectly.
  • Was tuned by Trent and Cat at Chequerred Tuning.
  • Everything work as from factory.
Had an oil leak from the front main seal, just recently (on the 19 Sep 2012) got it fixed - set me back $1000, for new seals and water pump and cambelt!
If u know me, u know how well i take care of my cars, one drive and u will see.
Sound system in atm will be removed when sold, but doors are sound deadened.
Wheels will not come with sale (cheap wheels anyways) i have the stock wheels in black paint with near perfect tires on them.
Car dynod in at 176rwkw, drives absolutely perfect, was slowly building it to oneday drift it, but as u can see its too nice to drift and that would kill it.
Has been my daily driver for the past few years, but reecently sold my business and have commenced studying again and need a car I can leave at the train station without worrying that my beloved r32 will get stolen, scratched or broken into etc.
THE BAD POINTS
Car needs paint on the roof as it is a bit oxidized. The car is from 1992, so paint isnt going be absolutely perfect.
There is a small dint near the fuel cap, where the previous owner had given his car to his mechanic and the mechanic reversed the car into a pole, Probably cos the tint is so dark haha
Will provide RWC, but to do so will need to remove tint.
Asking $10K with RWC.
$9.5K Without RWC. As this saves time and i dont have to mess around having to remove tint and organise RWC. will put some more pics up as soon as i get a chance. I will be overseas from 26th sep to 10th Oct, so if u contact me between then, please be patient and ill get back to u asap.
Car is 100% roadworthy other than tint.
Reg Expires 21 Nov 2012.
Please, no tire kickers.
I have the stock exhaust and stock turbo that i can include in sale if sells for asked price.
I am currently looking for an EG Civic, cheap run around car, body doesnt have to be immmaculate but needs to have rego, come Rwc, have aircon, heater, be manual and have vtec. (preferred motors D15B Stage 3 vtec, B16A, B16B, B18C (engineered only). Engine must be registered to car.
Thanks.
Marcus.
0415 038 232.
http://www.skylinesa...5010_285039.jpg
^^^small dint pic^^^
Edited by Widesays
https://www.sau.com.au/forums/topic/409798-fs-r32-gts-t-1992-rb20det/
Car also has Z32 AFM and K&N panel air filter.
Here's some more pics and a quick walk around video I took yesterday (22nd Sept. 2012).
Video:
Pics:
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_1637804.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_1281097.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_1724308.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_921259.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_1568342.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_561508.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_22487.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_553248.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_920757.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_142684.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_298170.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_157750.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_567962.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_882140.jpg
http://www.skylinesaustralia.com/forums/uploads/gallery/album_5010/gallery_88630_5010_626716.jpg
Went a bit nuts on pics, but its hard capture how clean and well looked after this car is.
  • 3 weeks later...
  • 3 weeks later...
Spoke to the guy before, he got defected and had to get his mechanic to sign a stat dec declaring that the intercooler was using factory mounts or something, obviously it has a hole cut for the cooler piping so his mechanic doesn't know what he is doing :closedeyes:
Just thought I'd let people know in case they thought he had the cooler engineered.
Edited by eightsixboy
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
