Noise restrictions apply.
Must have CAMS L2S and CAMS Affiliated club membership (SAU VIC).
The scrutineering here is a little tighter than elsewhere. So make sure your fire ext are BOLTED in and are within the 3 YEAR
date cycle.
Standard double latch bonnets are fine.
Normal helmet and clothing rules apply.
http://www.maserati.org.au/download/pdf-files/Sand-141012-Supp-regs-Entry-CAMS-OK.pdf
https://www.sau.com.au/forums/topic/409808-14th-oct-maserati/
  • Replies 79
It runs pretty much the same.
- They run a split roast for lunch
- Stop for lunch
- 4 colour groups
- White, Red, Yellow and Green
- Generally Red or Yellow will get split into A and B (two different groups), so 5 total.
- Maserati club members generally have older cars, thus by the end of the day they are either fat on lunch and don't go out or their car is busted
- Not that many exotic turn up actually, more ex tarmac rally cars and the like. You do get the odd lambo and feza turn up
The sound restrictions do suck, the track was there before the house yada. But that is what we have to deal with, so if you have ext gate you are f*ked. Plain and simple (there are exceptions, but you have to do a lot of work to the exhaust to quieten it down)
I've never triggered it at Sandown so it's not as bad as you would think
it just dosent make sense to me why they would put it at that level.
if they put it at 90 or 95 whatever the Vic EPA legel limit is, then that makes sense
EPA is right at the exhaust, this is from 30 meters, across the track and over a wall...there is a big difference.
what he says
mine is no-where near road legal, but never triggered Sandowns noise restrictions.
M
ive had a major epa done before on my old skyline, emissions were measured at the exhaust, noise from a distance
anyways im more just having a windge about the fact its a race track and you cant go make noise :/
street epa is measured at 1 meter..30 makes a huge diff.
that said according to PI I am borderline as it is....so winton wins again
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
