Noise restrictions apply.
Must have CAMS L2S and CAMS Affiliated club membership (SAU VIC).
The scrutineering here is a little tighter than elsewhere. So make sure your fire ext are BOLTED in and are within the 3 YEAR
date cycle.
Standard double latch bonnets are fine.
Normal helmet and clothing rules apply.
http://www.maserati.org.au/download/pdf-files/Sand-141012-Supp-regs-Entry-CAMS-OK.pdf
https://www.sau.com.au/forums/topic/409808-14th-oct-maserati/
  • Replies 79
It runs pretty much the same.
- They run a split roast for lunch
- Stop for lunch
- 4 colour groups
- White, Red, Yellow and Green
- Generally Red or Yellow will get split into A and B (two different groups), so 5 total.
- Maserati club members generally have older cars, thus by the end of the day they are either fat on lunch and don't go out or their car is busted
- Not that many exotic turn up actually, more ex tarmac rally cars and the like. You do get the odd lambo and feza turn up
The sound restrictions do suck, the track was there before the house yada. But that is what we have to deal with, so if you have ext gate you are f*ked. Plain and simple (there are exceptions, but you have to do a lot of work to the exhaust to quieten it down)
I've never triggered it at Sandown so it's not as bad as you would think
it just dosent make sense to me why they would put it at that level.
if they put it at 90 or 95 whatever the Vic EPA legel limit is, then that makes sense
EPA is right at the exhaust, this is from 30 meters, across the track and over a wall...there is a big difference.
what he says
mine is no-where near road legal, but never triggered Sandowns noise restrictions.
M
ive had a major epa done before on my old skyline, emissions were measured at the exhaust, noise from a distance
anyways im more just having a windge about the fact its a race track and you cant go make noise :/
street epa is measured at 1 meter..30 makes a huge diff.
that said according to PI I am borderline as it is....so winton wins again
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
