Of course it's the stock ECU. That's what the Uprev Osiris cable is made for. I didn't want to go through the process of wiring in another MoTeC like I did in my previous project. Modern cars in particular are so tightly integrated with all their other components that one does not tread lightly in the aftermarket ECU domain unless they want to lose all the creature comforts and some of the OEM performance benefits, such as the all-wheel steering and whatnot. This is where it's best to leave the stock ECU and remap it instead. That's the purpose of the Osiris.
Sorry, got lazy and didn't look up what Uprez Osiris was. Now that I did, did you do the tuning yourself or got a tuner to do it? Then again I wouldn't know what to look for in a tune, have not much experience in it. Might just go with tuners first and then maybe look at Uprev. It looks really interesting though.
Thanks for the info :) Will hit you up if I get more questions if you don't mind :)
I haven't yet done any tuning on it. I only got to drive it for a couple months before I had to fly off to the UK for 5 months work so there's a lot going on now that I'm back on home turf again. The tune will be the last thing I do. I no longer have access to a dyno like I used to so I'll be relying on the services of Tunehouse and hopefully the owner remembers me given I had long hair back in 2002 when we did the MoTeC training seminar. :)
If you know how to tune, it's a logical process but the butt dyno will only be good enough for getting a general tune. After which, a dyno is absolutely necessary for a fine tune and particularly with timing where you need to listen carefully for knocking so that you can dial the timing back a bit. Fuel's easy because you can read the lambda values from an EGO meter. It's spark that's the slightly trickier one.
Someone here has already had theirs tuned by someone in the Central Coast if I remember correctly. It's in their signature with every message they leave so keep an eye out for it. It definitely gives you the most gains for an NA mod and it's about as far as I'd go because I don't see the value in forking out cash on hardware that could be better spent doing a proper forced induction modification instead. Many here will disagree with me but we all still get along despite this difference. :)
Why hack into the ECU wiring loom if you don't have to? The only time I see a piggyback option being feasible/necessary is when you're going for massive upgrades which then require the use of sensors with different electrical characteristics. If all you're changing is the injectors and going mild boost, then an ECU reflash is more than enough.
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
