What? Why you need to know percentage just to get slotted rotors?
If changing calipers, sure, you might want to work it out, but what are you up to?
Go measure the size of the front and rear pistons, and work it out if its that important.
https://www.sau.com.au/forums/topic/409838-braking/#findComment-6544878
No I don't need to know percentage to get slotted rotors... try reading it again before typing your annoyance... :rolleyes:
I already have slotted rotors on the front. Im wondering what a good upgrade to the rears would be... thanks for not answering that question too btw.
And in answer to your question, I'm up to nothing.
I'm wanting to know how much front brakes work compared to the rears and if an upgrade to the rears would be worth it... and if someone knows the percentage it would help me in my decision.
https://www.sau.com.au/forums/topic/409838-braking/#findComment-6546946
Front/rear split is around 67/33.
Is it worth it? I still upgraded all four of my rotors to the DBA4000 series slotted variety and whacked in EBC Red Stuff pads all around too. May as well give them all the same treatment and the savings in not doing so isn't that significant.
https://www.sau.com.au/forums/topic/409838-braking/#findComment-6547171
    • I'd need to check my notes at work Duncan, but I'm pretty sure most of that is purely OBD2 on the display. How quickly is it all able to update? Do you have any internet capability in your workshop with a laptop?
    • Yeah just gonna be near stock runner only want 180kw to 210kw can’t find anything been looking ages looked in to rb25 but money is tight as the moment need the car back on the road
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
