1993 R33 gtst
Due to sumone running into me I'm forced to part out my car, most parts are available so if its not listed just text msg me.
Sum parts that are available
Series 2 RB25Det has done approx 105,000km, only installed 4 months ago
Has a tomie head gasket
(Selling as bare motor, no injectors, coilpacks or turbo kit)
$1500
R33 Det manual gearbox, has exdy brass button clutch and lightened flywheel
$1100
Genuine Gt 30/71r turbo kit
$1200
Turbosmart veeport bov
$150
3inch alloy Intake pipe
$80
Z32 afm with filter
$200
750cc injectors
$400
Spitfire coilpacks series 1
$400
Intercooler + pipping
$250
Power fc with hand controller
$1200
19inch chrome rims (front has slight buckle, rears have fresh rubber)
$600
Full exhaust from turbo back (3inch)
$700
Rolling shell with full interior minus electronics (it still has rego)
$2000
Series 2 front bar including fog lights and lower lip attachment (repairable)
$150
gtr wing (needs a paint, isn't genuine)
$150
Series 2 bonnet
$100
Series 2 headlights
$450
That's all that i can think of at the moment
as i said if its not listed just text msg me on 0435840516
If you need pics i can picture msg you afew so let me know
Edited by twotone33
https://www.sau.com.au/forums/topic/409877-nswwrecking-r33-gts-t/
Is the 3inch intake pipe just a pipe or does it had the inlets for plumback bov and cam cover breathers?
If it has them, I'm keen.
Cheers.
Rob.
Cheers.
Rob.
sorry mate can't help ya
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
