By jdmyo at 2012-04-21
Long block all togeather except lower cambelt cover. I also need to make up a piece to fit between the two covers to fill in the exposed space. Should get intake mani sorted this weekend and all aux. Still need to sort injectors and ECU but that should be it. Just have to build up the motivation to pull the motor out again..
By jdmyo at 2012-06-01
Got a few more bits, some good some cheap ( intake mani ) Have a tial BOV on the way and have started pulling the motor out of the car..
My work place
By cefiro at 2012-06-29
Old injectors on top 270cc, new injectors below 550cc ( series 4 rx7 . Business card from the guy i got them off..
Motor is ready to come out and BOV turned up.
By jdmyo at 2012-07-05
A bit more progress. I got the flywheel machined again because im pretty sure it was out of balance after the first time and it has some pretty wicked heat spots on it. Got new heater, fuel and water hoses. Got a spiggot bush from nissan for $10 aswell. Thought it would have been more genuine.
Started to re-wire the injectors to suit Bosch injectors. Gave the engine bay a clean up and started preping the wheels to be re painted.
By jdmyo at 2012-07-15
Picked up some parts to relocate the battery into the boot. I went with 35mm double insulated cable instead of 25mm because a few people told me i will get less voltage drop due to the length of the car. Only down side is i had to buy 10m of it. I was thinking maybe running the earth the length of the car as well should provide a better earth.
By jdmyo at 2012-07-16
Had my wheels painted satin grey, i did all the sanding which i now realise sux ***.. They came out looking pretty cool but i haven't put them on the car yet so not 100% sure if they will look as good on.... to late now..
By jdmyo at 2012-07-27
Painted the sub frame with POR15 so it will stay nice and shiney. Fitted all new hoses and braided lines before putting the motor back in today.
By jdmyo at 2012-08-05
Have been away for a few weekends so not a lot of progress. Injectors turned up from the states. Got an oil restrictor made up and thats about it.
By jdmyo at 2012-08-30
Got everything togeather and fired it up.. no leaks so thats a bonus. Idle is a little funny but will figure that out this weekend. Will hopefully send it off for a tune in a week or so..
By jdmyo at 2012-09-12
Had to lengthen both the TPS plugs.
Here are some photos in no particular order of what i have done since the last photo update..
Removed the standard 20det clutch after i ran the motor in and fitted a excedy 5 puk clutch. Broke the top hose fitting off the radiator ( not very impressed ). Wired in Z32 AFM. Took it to Torque Performance and had a nistune board fitted and a custom tune done. Got half way through shimming my spare diff. Did the front brakes. Went to powercruise. It rained. If ive missed something the pics will explain.
Now i just want to get out and use it.
img0156dq.jpg\
I forgot to take a pic of the dyno sheet so will do that next time im on the computer
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
