By jdmyo at 2012-04-21
Long block all togeather except lower cambelt cover. I also need to make up a piece to fit between the two covers to fill in the exposed space. Should get intake mani sorted this weekend and all aux. Still need to sort injectors and ECU but that should be it. Just have to build up the motivation to pull the motor out again..
By jdmyo at 2012-06-01
Got a few more bits, some good some cheap ( intake mani ) Have a tial BOV on the way and have started pulling the motor out of the car..
My work place
By cefiro at 2012-06-29
Old injectors on top 270cc, new injectors below 550cc ( series 4 rx7 . Business card from the guy i got them off..
Motor is ready to come out and BOV turned up.
By jdmyo at 2012-07-05
A bit more progress. I got the flywheel machined again because im pretty sure it was out of balance after the first time and it has some pretty wicked heat spots on it. Got new heater, fuel and water hoses. Got a spiggot bush from nissan for $10 aswell. Thought it would have been more genuine.
Started to re-wire the injectors to suit Bosch injectors. Gave the engine bay a clean up and started preping the wheels to be re painted.
By jdmyo at 2012-07-15
Picked up some parts to relocate the battery into the boot. I went with 35mm double insulated cable instead of 25mm because a few people told me i will get less voltage drop due to the length of the car. Only down side is i had to buy 10m of it. I was thinking maybe running the earth the length of the car as well should provide a better earth.
By jdmyo at 2012-07-16
Had my wheels painted satin grey, i did all the sanding which i now realise sux ***.. They came out looking pretty cool but i haven't put them on the car yet so not 100% sure if they will look as good on.... to late now..
By jdmyo at 2012-07-27
Painted the sub frame with POR15 so it will stay nice and shiney. Fitted all new hoses and braided lines before putting the motor back in today.
By jdmyo at 2012-08-05
Have been away for a few weekends so not a lot of progress. Injectors turned up from the states. Got an oil restrictor made up and thats about it.
By jdmyo at 2012-08-30
Got everything togeather and fired it up.. no leaks so thats a bonus. Idle is a little funny but will figure that out this weekend. Will hopefully send it off for a tune in a week or so..
By jdmyo at 2012-09-12
Had to lengthen both the TPS plugs.
Here are some photos in no particular order of what i have done since the last photo update..
Removed the standard 20det clutch after i ran the motor in and fitted a excedy 5 puk clutch. Broke the top hose fitting off the radiator ( not very impressed ). Wired in Z32 AFM. Took it to Torque Performance and had a nistune board fitted and a custom tune done. Got half way through shimming my spare diff. Did the front brakes. Went to powercruise. It rained. If ive missed something the pics will explain.
Now i just want to get out and use it.
img0156dq.jpg\
I forgot to take a pic of the dyno sheet so will do that next time im on the computer
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
