Greetings at you all.
Recentlyish I put a GTR BOV on my R33 GTS-t sedan just for fun and perhaps a little more Bov noise.
All was good for a day or so, then it started doing the weird fart noise at about zero psi.
I thought it may have been because I did the small hose inside a larger hose trick, so I got a 38mm - 28mm reducing style hose and put that on but it still does it.
So I made up a plate from some aluminium sheet and drilled some smallish holes in it to use as a gasket, thinking that the reduced flow to the plunger might help.
It gave me the flutters, so I made the holes bigger and back came the fart noise again.
If I block off the bleed hole on the outside of the BOV will this fix it?
That is the next thing I was going to try.
I have tried a different GTR BOV and it still farts at the same zero psi and put my GTS-t Bov back on and the farts stopped.
Yes the GTR spring is softer than the GTS-t and I guess the GTS-t bov leaks back into the piping but the GTR leaks out.
The car may even be more responsive with the GTS-t bov on?
Knowing that many people have used GTR bovs on GTS-t's and that this fart issue has come up before (as I have searched heavily but found no fixes). I am at a loss and am wondering if there is a reason it happens and a way to stop it.
If all else fails, I'll just use my GTS-t Bov again. No big issue.
In case it matters, I have K&N panel filter, silicon intake pipe, Stock Turbo, 10psi actuator, R34 smic, gutted cat and 3" catback blitz exhaust.
Any wisdom is much appreciated. :thumbsup:
TL;DR ???
Why does a GTR BOV on a GTS-t Fart?
How can the flatulence be stopped?
Rob.
https://www.sau.com.au/forums/topic/409915-gtr-bov-fart/
It comes down to what fuel you been running mate, u must of been running some shtty fuel and youve upset your cars insides, so it's not feeling very well and farting........
Soz had to do it
  • Like 1
https://www.sau.com.au/forums/topic/409915-gtr-bov-fart/#findComment-6545935
Maybe he was giving it some (baked) beans ...lol
sorry...i'm no help either
https://www.sau.com.au/forums/topic/409915-gtr-bov-fart/#findComment-6545995
Fuel is Caltex 98 always. (i know you is justa be a funny). Case of gastro?
lol, yeah if I give it the (baked)beans, it's not a problem as at boost it all works normally.
It's only when it is at 0psi and I can make it happen for ages if I feather the throttle.
Do GTS-t bovs stay open at light cruise? In my head, I can see the plunger doing a weird vibration as it closes but I'm only speculating.
Guess it has to do with a softer spring/larger bore?
As far as a video goes, there is one in this link which is an identical sound.
4th post down.
http://www.skylinesaustralia.com/forums/topic/272686-gtr-bov-in-gtt-not-sounding-right/page__hl__gtr%20bov%20
fart sound happens briefly at 6 seconds.
Edited by Not a Pulsar
https://www.sau.com.au/forums/topic/409915-gtr-bov-fart/#findComment-6546036
yep, I've had that noise, but I relocated my gtr bov when I got a bigger turbo and moved the afm to the hot side of the turbo. mine made that sound as soon as there was any boost it sounded like a train's horn, just a constant noise of what's in that video @ 6 sec.
it's the bov opening on light cruise as aggroman said. can't tell you if yours is buggered or not, not sure why some people are fine and some aren't. when I did swap my gtst bov for a gtr's I did notice that the diaphragm inside the gtst one was alot harder to push in the the gtr's.... the gtr bov was fine until the bigger turbo.
so I just got one similar to this -> http://www.turbosmar...umb-back-nissan that I could tighten and made it as tight as possible, which it needed to be as the bov is 15cm away from afm which could causes issues if it's leaking on idle/cruise.
Not to say there is anything wrong with gtr bovs, I liked mine, but right tool for the right job.
may have been this one as it is adjustable... http://www.turbosmar...duct/plumb-back but I know the current one I have is mostly black.
https://www.sau.com.au/forums/topic/409915-gtr-bov-fart/#findComment-6546113
  • 4 weeks later...
Ok, so I've tried 3 different GTR Bov's, and it still happens.
Tried a different vac hose as the GTS-t hose seems slightly looser on the GTR nipple. Still does it.
Tried blocking the little hole on the side which stopped air coming out when the spring compressed and made it stiffer. Still does it.
Back to the GTS-t stockie pitchewwwwww.
I know the GTR Bov is unnecessary but it sounds a little nicer and well hey... It's off a GTR !!!
Anyone know the reason / fix for the GTR BOV FARTS???
https://www.sau.com.au/forums/topic/409915-gtr-bov-fart/#findComment-6586759
  • 8 months later...
So today I installed a gtr bov I bought. Had this problem so googled it and look what came up Rob! Haha..
You didn't happen to find a solution to this did you...?
Hahaha! Nice one. :D I think Mik has a thread on it too.
Well I swapped to a different GTR BOV but I put on my Metal intake at the same time. Whether the intake helped or not I don't know, I don't get that sound atm but I don't know what fixed it.
I might do a swap back and see what happens. I actually just put my GTS-t BOV back on yesterday just to see what it's like with the metal intake and Pod. It's heaps better than stock but the GTR sounds better.
I will be changing it back.
as far as air escaping at the flange goes, I use the same gasket as the GTS-t BOV and it isn't a problem.
https://www.sau.com.au/forums/topic/409915-gtr-bov-fart/#findComment-6910263
Ah ok, thats alright. I don't it's causing any harm.. Just sounds weird..
I'll just get used to it and it can join the rest of the mad wisping sounds that come from a podded turbo lol
https://www.sau.com.au/forums/topic/409915-gtr-bov-fart/#findComment-6911212
I have a GTR blow off valve on mine, have tried 2 and never had any fart noises, id say its likely to be a leak from the gasket as ive previously had the same noise from a leaking intake plenum gasket. Clean all surfaces and apply generous amounts of gasket goo and see if the noise goes away...
That fart noise is the same as blowing on an A4 piece of paper with your lips which would make sense if air was leaking from the area with some pressure.
  • Like 1
https://www.sau.com.au/forums/topic/409915-gtr-bov-fart/#findComment-6911745
  • 6 months later...
    • The plan is to get it out of the shed. The reality may fall some way short. But hope is as cheap as despair as they say. Will go a wide band I think. The coils are ok so maybe I’ll miss the $1500 on the R35 coils etc. Im still on the fence about a trigger kit. The HKS one looks nice ($1k) - not sure how it works with the Link or if Link prefer something else. Oil pressure is fine so I’m not that concerned there. Fuel pressure I’ll have a think about. The IAT got changed for the Link anyway as the old RB26 ones were really slow reacting and pretty poor. The Power FC just worked. Wasn’t terribly refined but it just worked. Probably made a mistake replacing it really. E85 isn’t available locally - it is 100+ kms away which puts it in the too hard basket. Lastly I understand Tunecorp in Perth are pretty good so was probably going there.   As for turbos is there are new age -5 drop in replacement? Turbos have come a long way in 20 years, everyone is big single which is fair enough but I prefer the old school complication of twins. Wasn’t chasing more power (well, not much more) but more efficiency would be ok.
    • I thought I'd share this....the shell is non genuine but they found or built a lot of the genuine parts. Plus, it is by far the best colour scheme of those years, the winfield once was particularly shit https://www.v8sleuth.com.au/written-off-inaugural-godzilla-recreated/
    • Good work Pete and glad the car held up well....been a while since I've seen you try properly
    • Just quick update, I've had tech issues and so a backlog on life stuff....I will pull lap times from the video and data from the ECU logs to do a proper update. But basically, in order of importance: 1. The car was excellent fun on the track, really felt a lot like the good old days. And nice to have AC while waiting 2. Coolant got really hot; again I need to pull and analyse the logs but the standard system is not up to tracking at 30o+ days, once the system was heat soaked after the first 2x15min sessions I could only do 3 laps before it got 110+ and I had to cool down. If I can't improve that it is a deal breaker 3 Oil temps were fine all day, noting it was short sessions due to 2. I think it will likely need work 4 Biggest surprise AT temps were fine, never went over 100, I would have been OK with 120 before I was too concerned. The auto sucks compared to a manual (of course) but it is faster to launch and I just need to downshift it manually before hitting the throttle, then it was OK. When I post the vids you'll hear it telling me off (beeping) for trying to downshift too early (it needs about 3500 before it will downshift, depending on gear a little but we are mostly talking 3/2 and 4/3) 5 A052s were not great which hurt the lap times, but I will be constrained in what I can get in good tyres that fit the wheel wells. These were small for a heavy car at 235/45/18. In theory I can fit 9.5 on front and 10.5 rear (so not square) but I still need 670mm+ high tyres in good brands. 6 Standard shocks/springs/roll bar are too soft for track work (of course), but that was always on the list. And happily, no white on the mat, despite having a teenaged passenger, extinguisher mount was fine. Also, it was nice to have Wakefield Park back in action  . Because the car was so quiet it is eligible for Green Day, which I thought was a band but is apparently a series of cheaper practice days they run with a lower sound limit, that is a smart idea.
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
