Its not the gasket.
My guess:
It is an oscillation of the diaphragm, because the setup is different on a gtr, the pressure settings for open and closed arent right for gtst.
The throttle flap is much closer to the bov on rb25 and 20, so it would react different when you shut the throttle on an rb26 with throttle bodies closer to the head.
This is also relative to where the bov activation hose is located.
So its probly a pressure wave that is going just the right distance (or wrong distance cos its not right) to make it open and shut so quickly.
Never thought of the Proximity thing. Good thinkin' Mik.
And yeah, It's not Gasket flap. I reckon the aged spring and diaphragm gets the vibes and gives out the Frooty noise. Some do it, some don't.
Still reckon the GTS-t Bov makes for better throttle response anyhow.
I've been running a GTR BOV on my 25Neo for a few months. When it first went on I was sufficiently amused by the farty noise that it took me a while to realise that the car no longer felt as peppy coming onto boost as it had been before. Swapped back to the RB20 BOV (that's what I was using on my car since the Neo transplant went in, they're supposed to be the same thing anyway) yesterday. In my very brief unscientific testing since, I am sure that the car comes on boost more briskly with the little BOV.
It takes more finger force to push the GTSt BOV valve open. I'm not sure what that means. I haven't fully thought through (or done any testing against a vaccum pump) to see what it takes to make each of the open to know whether one being open more that than other of for longer as post turbo pressure starts to rise is enough to make the car perform differently. I suppose if the bigger GTR BOV is open until later in the accel event, then it will waste more pressure back to the turbo inlet before it finally shuts and therefore soften the boost rise rate.
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
