If you look up the splitfire website it will tell you which coils fit.
My preference
1. New OEM if you can get them at a good price
2. Splitfire
3. Yellowjackets
None of the rest.
This one I think:
http://www.kudosmoto...005-p-1115.html
Actually at $410 plus postage I think the Yellowjackets would be the better buy:
YJ-RB2526-S2
http://www.performance-wise.com/userimages/procart28.htm
https://www.sau.com.au/forums/topic/409935-what-coil-pack/#findComment-6546154
I've just done coils, went with the yellow jackets. They suited my busker and have had good reviews, and I could not be happier!! They are amazing. Didn't think it would be such a noticeable difference, but everything just feels better!
Rb25det s2 stagea
Edited by Waino99
https://www.sau.com.au/forums/topic/409935-what-coil-pack/#findComment-6546637
Very hard to get any objective results.
I like the OEM (brand new) because they have been proven to last 10 - 15 years!
Splitfires have built up a reasonable record by now.
The Yellow jackets have stood up well on the dyno and on the track.
Some of the others have failed relatively early in life.
The test is not whether one makes more power than another - they are just coils after all - but how reliable they are.
https://www.sau.com.au/forums/topic/409935-what-coil-pack/#findComment-6546981
Talking about plugs. I bought a set to suit "RB25DET" I never really looked at them except to gap to 0.8mm. Stag is not too happy with plugs, now I see they are "7" not "6". Whats the difference?
https://www.sau.com.au/forums/topic/409935-what-coil-pack/#findComment-6547490
Heat range, Were they for your 25DET or for your DE? 6 would be better for relatively stock DET and 5 for DE
https://www.sau.com.au/forums/topic/409935-what-coil-pack/#findComment-6548789
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
