Hello any help would be great,
My C34 is currently leaking oil from near the oil filter, I'm 99% sure its not the oil filter because when i grab it with clean hands the filter and the filter block are clean. It looks like its coming from the part in the pics iv attached it might be the factory oil cooler? not to sure just wondering if anyone knows of a common leak that can develop in this area? I cant get a good look in there and I have big hands LOL, also its leaking a fair bit of oil so I need it fixed asap.
thanks guys
Rhet
https://www.sau.com.au/forums/topic/409953-rb25-oil-leak/
That's an iunisual place for an oli leak, the cooler is a bolt on arrangement and unles you have removed it there sholud be no problem, how much oil are you loosing it might be coming from above, cam covers are prone to coming loose, try tightening the covers maybe.
https://www.sau.com.au/forums/topic/409953-rb25-oil-leak/#findComment-6546557
I have a remote oil filter in which I have oil temp and oil pressure sensors for dash mounted gauges. I run single din and gauges fill space.it is cool and practical.No leaks.
https://www.sau.com.au/forums/topic/409953-rb25-oil-leak/#findComment-6546593
It is loosing a bit, a little 10cm puddle when I park over night. It has never been removed as far as I know. I did look to see if it was coming from higher and didn't see anything but I'll have a proper look tomorrow again.
https://www.sau.com.au/forums/topic/409953-rb25-oil-leak/#findComment-6546840
  • 1 month later...
Hello again fine sirs! after repairing the first oil leak i have found another, oil is seeping from the very front of the sensor to the left/below the oil filter. Right from the front just behind the screw that holds the tab/electrode thing for the sensor wiring. Now is this the oil pressure sensor? i'm thinking it may be best to replace the whole thing? any advice?
cheers guys, this is really starting to shit me!
Edited by horrace
https://www.sau.com.au/forums/topic/409953-rb25-oil-leak/#findComment-6608819
Agreed with Dale. Hey Rhet, does your oil light on your dash work? I was wondering from viewing the first pic why it was disconnected. That brown plug flappin' in the wind in the pics should most likely be connected to it..........
https://www.sau.com.au/forums/topic/409953-rb25-oil-leak/#findComment-6609172
  • 2 years later...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
