M35 passenger side rocker cover gasket DIY
i hold no responsibility for any person hurt or cars damaged while using this DIY tutorial.
tools needed:
1/4 socket set (10mm, 12mm, extensions and knuckle)
10mm spanner
magnet (so you dont lose bolts)
flat head screwdriver
super RTV silicone (you dont have to use this)
degreaser or brake cleaner
rags
scraper
rocker cover gasket
1. remove engine cover, then remove intake pipe both sides, stuff rags inside the intercooler pipe so not to lose bolts. undo surrounding plugs and place out of the way (if you can)
2. then get the 12mm socket and undo the plenum bolts, and behind the plenum use a 10mm spanner to remove a small bracket. once undone you should be able to pull the plenum aside and get to the rocker cover bolts.
3. once you can see the rocker cover clearly, remove the coil packs (make sure to mark the plugs so u know which goes where) now get the 10mm socket with extension and start to remove the rocker bolts, use the magnet to catch the bolts, you will encounter 3 that can be hard to get to (the back left corner under the hose and the next 2 towards the front of the car, make sure you dont drop them)
the bolt is under this hose
4. now use a flat head at the front of the rocker cover and gently pry it upwards until the seal brakes, then remove the rocker cover, and put some rags over the exposed engine.
5. then get a rag with some degreaser or brake cleaner and clean the sealing area on the engine (mine had some grey silicone on the front which had to be scraped off), then degrease the rocker cover and clean the edge (i used the corner of a rag and ran around the inside of the seal point)
6. once the rocker cover is clean, fit the rocker cover gasket inside the rocker cover and use some silicone in the corners to help it stay in place, wait a minute or two so the silicone hold better. then put the rocker cover back on the engine (you will need to lift the hose at the back to make it easyer) once it is in place and you have checked that it hasnt falling out of place. you can then put the bolts back in place being careful not to drop them (magnet helps) and tighten. then reverse steps 2 and 1.
ok im pretty sure thats everything you need to know about doing the rocker cover, just remember to remove the plenum i tryed to do it without removing it, it didnt work.
  • Like 1
https://www.sau.com.au/forums/topic/409966-m35-stagea-diy-rocker-cover-gasket/
  • 4 years later...
hi guys i see this is abit of an old post but glad i have found it as i wasnt to sure if i would need to remove the plenum or not , would it pay to replace the inlet gasket while its apart or would it be ok to leave in there , cheers
  • 9 months later...
Good write up.  Order is pretty much right.
So if you are going to try this at home, I suggest leaving at least 5-6 hours, which includes a bit of swearing, dropping tools/bolts and stuff in general and degreasing everything.
Those bolts at the back of the plenum are sure to be broken once you have a crack at them with the 10mm spanner/socket.  So get a few spare for this job.  Squirt a bit of WD40 before you consider doing this job!  Probably crack them when the manifold is hot!
  • Like 1
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
