G'day Fellas,
If you are stressed about whether or not a Nissan Technician put an "Autech" sticker on a car during initial build... then this is not the car for you. In fact, a stock car is probably more your speed. In saying that, you could always spring for the extra couple of bucks to buy an Autech sticker... because we all know that Nismo and Autech stickers add kW like there's no tomorrow :laugh:
There's just not that many Autech's modified to this level, and any that are for sale asking similar prices generally have either some pretty low level mods done to fuel/boost, or have significant problems... and simply aren't even in the same performance ballpark. This has had so much more integrated than simply dropping an RB26 in it!
If you're searching for that Autech that's as complete a package as this car, you're simply gonna have to pay a lot more dollars. Sometimes expectations just need to be adjusted.
But, to show I listen to the punters, here's a price reduction for ya...
$22,000 ono
110,153km on the clock
Will be doing the 6 monthly oil & filter service in the next couple of weeks (travelled less than 450km since Jan).
If you are about badges over substance, go buy a Mercedes!
  • 3 weeks later...
6 month Oil and Filter service done today at 110,210km. Used Penrite 10 Tenths Racing 10-40W oil the std Ryco Z56B, plus a dose of MBL-8.
$21,900 ono
put that tax return to good use!
  • 1 month later...
  • 1 month later...
Back from interstate, and have just renewed registration for another 6 months.
I have to sell the car now, it's costing too much in unused rego, insurance and 6 monthly maintenance.. so price reduction time:
$20,300
only 110,341km
HKS 2530's freshly reconditioned by GCG in Sept 13!
  • 4 months later...
  • 1 month later...
I can't believe this is still here!
Still the best Stagea I've come across, unfortunately it was out of my price range when I was shopping, but surely SOMEONE with the funds and appreciation for this vehicle is around!!??!
Car price has been reduced to $19,000. Probably should have posted that a while back, oops.
Car is almost SOLD... just waiting for funds transfer in early June. This time is a genuine sale
Thanks for the props fellas. The fact this car hasn't been sold until now is purely a reflection of the used import turbo market over the past 12 months. Heaven if you are a buyer... demoralising if you are a seller.
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
