Ive changed my mind about the build more parts added
Rochester 660cc x 6 injectors top feed for rb26 270
rb26 head complete with everything including covers 1200
Rb26 block virgin 300
Rb26 plenum and throttle bodies 290
Rb26 r32 Gtr sump complete 150
Rb26 crank from r32 Gtr come from running motor 270
R33 fuel rail $40
R32 Gtr fuel pump 80
R32 Gtr working coil packs $30 each I have 5
R32 Gtr gtst dash small bubble 50
Rb26 rods $80 come from running motor
Rb26 stock oil cooler 40
Rb26 gtr air con pump $60
R32 air con condenser and lines 60
Rb26 balancer 40
Rb26 oil pump 40
Rb26 water pump 30
Rb26 alternator $50
Rb26 turbo manifolds $40
Rb26 turbo oil and water steel lines $30
Rb26 twin turbo pipe $40
Rb26 heat shields for manifolds I have 2 sets 40
R32 Gtr standard suspension 50
Impul gear knob 20
Rb26 alloy engine brackets 30
Rb26 engine mounts used but appear to be ok 20
R33 Gtr gearbox under plenum loom 40
Rb26 turbo intake pipes 30
Pioneer cheap cd player 20
Rb26 gearbox mount 30
Rb gearbox plate goes in between block and flywheel 30
Rb26 air reg 70
Rb26 r32 Gtr acc valve 40
Location gold coast but happy to post most things
0487924497
post-50709-0-26751800-1348459652_thumb.jpgpost-50709-0-49989800-1348459665_thumb.jpgpost-50709-0-64859100-1348459673_thumb.jpgpost-50709-0-65374000-1348459688_thumb.jpgpost-50709-0-95886700-1348459700_thumb.jpgpost-50709-0-69248200-1348459730_thumb.jpg
Edited by toy515
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
