Hi guys,
I had my R34 over the pits today and got reamed by an inspector who obviously did not get laid the night before.
As a result I have an inspection list with "VSS App required" next to a few items, including coilovers, intercooler, pod filter, trailing arms, castor rods and steering box/rack.
What is the correct proceedure to get these accepted? Do I have to fill out the Modification Application first, then get engineering certificates? Or do I get engineering certificates straight away?
I'm confused, and the rude inspector walked away without allowing me to ask any questions
https://www.sau.com.au/forums/topic/410047-car-mod-permit-question/
I am in the process of doing exactly what happened to you
You need to submit the application for mods straight away
Wait 2 weeks and they will send you a form which lists the things they need from the engineer
Submit engineers certificate and wait another 2 weeks and see how it goes
Meanwhile your yellow will run out and you'll have to get an extension which means another pit inspection
Feel free to call me
I can give you a really good engineer and some tips as I have been through the reaming machine and now know the process
Grant 0413775441
pod filter is easy change
either mount it securely or go back to an airbox
coilovers
farking farkedy fark fark
no need for permit - its not even yellow stickerable UNLESS they are wound too low
suspension mods in general are fine GIVEN that they are made for the car that they are going into and are a replacement part (ie s13 coilovers INTO an s13)
heim jointed items also from my understanding need to be engineered (or at least looked at by engineer) because there is no compliance in the device and could cause binding (or some shit like that)
intercooler - im not sure if it has to be engineered - but i believe that if there is no cutting of the bumper reo you *should* be fine
if all else fails - read the National Code of Practice documents in relation to vehicle design and modification
NCOP11_Section_LS_Tyres_Suspension_Steering is the document you want for the suspension stuff
Thanks 342four.
I'm thinking of leaving the pod and fmic and submit them in the application for mods and hope for the best. Getting the fmic out will be a pain. The pod is secured already but they still requested application for it.
Hopefully the fmic and pod won't need to be engineered.
Was it a simple modification permit form or full engineering check?
Engineers report was required for pod FMIC and aftermarket struts (with camber adj arms)
But they were giving me the full treatment after I gave them some backchat and a burnout, so you may be lucky.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
