1991 R32 GTR
Car is making 270rwkw on 18 psi on a very safe tune.
GT-C Volk 18x9's all round.
Motor rebuilt approx 10000km ago
Reco block + head were used.
chemical clean all parts, full machine, clearance and blueprint.
ACL comp bearings
JE Forged piston kit
H-beam rods
MLSR steel head gasket
oil restrictors
Genuine nissan gasket set
all new hoses
new genuine thermostat
new water pump
new timing belt
nismo radiator cap
new battery
new heater core
re gassed air con
nismo diff bushes
cradle spacers (pineapples)
600cc injectors
Splitfire Coilpacks
nismo plugs
Garret 28/60 turbos -7
Apexi power fc with hand controller
full kakimoto 3' exhaust
blitz 4 stage boost controler
R33 GTR crank
N1 oil pump
momo stearing wheel+ gear knob.
Tomei 310km dash cluster
new slotted rotors all round (dba)
koyo rad radiator
baffled sump
bosch fuel pump
central locking + alarm and immobilizer
Exedy button clutch (under 1000km)
Good stereo
Car interior has been retrimmed in leather
Bad Points:
Car has surface rust under drivers side rear quarter
Needs rear brake pads
Gearbox is knochty (Comes with r33gtr replacement gearbox)
a small dent on left rear quarter
Car is currently in Tasmanian Rego and that is how it will be sold. Located in Vic
I have over 15,000 in receipts for motor rebuild
16,800 ONO May consider swaps.
Contact me via 0467982414 or PM
Edited by s13en
https://www.sau.com.au/forums/topic/410057-fs-r32-gtr/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
