  • 3 months later...
just did this too i found it easier with removing guard liner you get so much room to work with too.
Takes >5 min to get it thru without inner guard , if you have tape, silicone spray, and stiff wire
But either way works
haha all good boys found it the gommet. the key point is to pull back the guard lining ! u cant see it other wise ! once i did that i run the cable in 15 mins !
and the last system i built i got a 145db with 2 12s running off 2.5k rms on music so i have a little experience with car audio !
cheers guys thanks for the help !!!!
Yeah its deceptive you can get to it from the engine bay but it is inside the guard it comes out behind the fuse box in the drivers kick. You can fit a semi trailer through it so the 0 gauge is fine. This grommet is there on almost all Nissan Imports S13/S14/S15 R32/R33/R34 180SX etc. Great for running cables neatly and out of sight. Pictures probably would have made it easier to find.
Funny about that , its a pain on iphones haha
where it comes in from under the lining.
you can fish out the cable or just poke it through and hope that it comes out next to the fuses. Its doable without having to fish it out if you prefer not to.
the grommet rubber lining
dont forget to put a fuse inline you can purchase the inline fuses from jaycar or audio shops.Prefer the old tech cylindircal ones as theyre also water tight and very simple screw and go.
  • Like 1
The screw together ones fail to easy
The plastic threads get crossed up or break off
The cables do not positive lock and can work loose
The housings crack from heat in a turbo bay or any V style motors from header heat
Not recommended !!
And jaycars are just the same as fleabay made in china ones !!
Not recommended !!
as i said i prefer those for simplicity of an anologue setup ten years down the line it will still be working but the digital new stuff, too much variables.With cracking place it under the lining but i really doubt that it would crack. Each to their own.
After nearly 26 years in pro car audio
They fail !! Often , even faster in oz heat
the new ones digital as you put it ? Which has nothing to do with it fail less , but a good old resetable curcuit breaker works well too , has a heat proof bakelite contruction as well
And ring terminals dont normally fall out
And never have to buy fuse at 2-9 bucks a pop
with those you need a straight run in and out or the allen set screw works loose on heat and cool cycles or fiddling with the wires
Just many better choices for same cost
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
