I wired up my MFD as an aux for my dvd deck when the TV button is pressed,right now it will play dvd's or the PS2 i've hooked up to the AUX on my deck( make sure anything you get whether it be a deck or tuner has NTSC output you can select as the MFD wont work with PAL systems), My deck does have TV tuner capability with the right module added on but i didnt bother with it, cant see any reason why you cant do this then connect it to whatever tuner you go with.
https://www.sau.com.au/forums/topic/410076-tv-in-34-gtr/#findComment-6548774
if the question is - can I do it - yes I can. regardless if the car actually had the TV tuner in it or not.
enough digging on here will net the info you need to make it happen.
https://www.sau.com.au/forums/topic/410076-tv-in-34-gtr/#findComment-6555630
