fast fours did a feature on it a few months ago:
2.2L ecotec 4 banger
custom t76 turbocharger
Spearco water to air intercooler
10 1600CC injectors
FAST ECU
4 speed dog box
ported head, solid lifters, aftermarket valves/camshafts/valve springs.
all internals replaced with stronger items or race prepped
state of the art suspension set up tuned to perfection
when it ran a 8.04 it didnt use nos, this time i am unsure if it did or not, but im sure theres more left in it
About the most I know about Saturn is that a good deal of their cars use plastic panels (like door skins etc) to save costs. Good for your supermarket car park fender benders I suppose.
A friend of mine in the US had a saturn and f'ing hated it. The build quality seemed fairly poor.
Not that this has anything to do, or is related in any way, to the 7 second saturn which i doubt has plastic panels.
and their cars from the 90s weren't exactly good looking either.
Damn good time though - how did they do it? I mean I always thought fwds couldn't do times like that because all the weight transfers to the back of the car on take off?
The Americans have nearly perfected the black art of getting a front-driver to hook up. Comes from racing Hondas for all those years I guess. They use long wheelie bars, not for any fear that the car will do a wheelstand ( :D ), but to extend the wheelbase. They set them very stiff. Weight transfer is the enemy in a front drive drag car. Suspension setup bears no relation to a rear-driver . . . it's weird, but really cool.
J
the abel abera rx7 uses 2 pwr water to air barrel cooler and runs methonal or similar, just becaust its a cooler burning fuel dosent mean it cant be run cooler into the engine. when they run extreme boost like those cars would there would still be alot of heat in the intake
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
