Hey guys I have 100000k stock block. Bent rods(hydrolock) I have found a really good deal on rb26 forged rods and cp pistons. They are stock 86mm size. Whats the possibility of the bore still being good? I've found a cheap rb26 crank to go with the rods and pistons aswell
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/
If the bores are fine then yes, normally you can just hone them and put standard sized (86mm) pistons in. You know 26 pistons will usually give you a lower compression ratio than standard 25 right?
It sounds like your best option could be simply sourcing a good complete stocker bottom end and throwing your head on it. Assuming you don't need a built motor?
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6550348
I thought if I go 26 crank aswell it won't?
Dnt need a built motor but it's either the forged rods and pistons or re ring the pistons that r in it and new bearings. I know it will be cheaper to get a new motor but I'd like to learn how to do all this
Edited by zac320
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6550524
Hey guys the local mechanic has convinced me to just put a new motor in. So I'm chasing a rb25 bottom end. No need for head or any other accessories. Just block to sump. It needs to be in good condition.
Cheaper the better especially if ur out of Vic as I'll have to freight it
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6553856
I have the bottom end here and I'm struggling to source a bottom end for cheap so. I'm thinking acid dip and hone block and clean up pistons and basic rebuild.
Bearings mains and rod $200
OEM rings $190
Nissan gasket kit $200
Rb26 rods $75 ( second hand from friend)
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6554057
I am going to do it. Took it to the Best local engine builder around and he doesn't want to do half the things, eg install rings on pistons but I install pistons. As he doesn't want to be liable if anything f**ks up. But he said I can take me engine into his workshop and do it there and ask for his advice which will be a great learning experience for me.
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6554109
im in your exact shoes.
it was option 1: buy 2nd hand unknown condition motor from someone.
or what i chose, option 2: rebuild, refresh and toughen up ("toughen up" being used lightly) my existing motor (ACL bearings, ross tuff harmonic balancer, crank oil drive thingo, ARP headstuds etc etc).
i think i would be kicking myself if i started getting huge blow-by after 12 months of getting a 2nd hand motor.
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6555672
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
