Hey guys I have 100000k stock block. Bent rods(hydrolock) I have found a really good deal on rb26 forged rods and cp pistons. They are stock 86mm size. Whats the possibility of the bore still being good? I've found a cheap rb26 crank to go with the rods and pistons aswell
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/
If the bores are fine then yes, normally you can just hone them and put standard sized (86mm) pistons in. You know 26 pistons will usually give you a lower compression ratio than standard 25 right?
It sounds like your best option could be simply sourcing a good complete stocker bottom end and throwing your head on it. Assuming you don't need a built motor?
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6550348
I thought if I go 26 crank aswell it won't?
Dnt need a built motor but it's either the forged rods and pistons or re ring the pistons that r in it and new bearings. I know it will be cheaper to get a new motor but I'd like to learn how to do all this
Edited by zac320
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6550524
Hey guys the local mechanic has convinced me to just put a new motor in. So I'm chasing a rb25 bottom end. No need for head or any other accessories. Just block to sump. It needs to be in good condition.
Cheaper the better especially if ur out of Vic as I'll have to freight it
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6553856
I have the bottom end here and I'm struggling to source a bottom end for cheap so. I'm thinking acid dip and hone block and clean up pistons and basic rebuild.
Bearings mains and rod $200
OEM rings $190
Nissan gasket kit $200
Rb26 rods $75 ( second hand from friend)
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6554057
I am going to do it. Took it to the Best local engine builder around and he doesn't want to do half the things, eg install rings on pistons but I install pistons. As he doesn't want to be liable if anything f**ks up. But he said I can take me engine into his workshop and do it there and ask for his advice which will be a great learning experience for me.
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6554109
im in your exact shoes.
it was option 1: buy 2nd hand unknown condition motor from someone.
or what i chose, option 2: rebuild, refresh and toughen up ("toughen up" being used lightly) my existing motor (ACL bearings, ross tuff harmonic balancer, crank oil drive thingo, ARP headstuds etc etc).
i think i would be kicking myself if i started getting huge blow-by after 12 months of getting a 2nd hand motor.
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6555672
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
