Hey guys I have 100000k stock block. Bent rods(hydrolock) I have found a really good deal on rb26 forged rods and cp pistons. They are stock 86mm size. Whats the possibility of the bore still being good? I've found a cheap rb26 crank to go with the rods and pistons aswell
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/
If the bores are fine then yes, normally you can just hone them and put standard sized (86mm) pistons in. You know 26 pistons will usually give you a lower compression ratio than standard 25 right?
It sounds like your best option could be simply sourcing a good complete stocker bottom end and throwing your head on it. Assuming you don't need a built motor?
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6550348
I thought if I go 26 crank aswell it won't?
Dnt need a built motor but it's either the forged rods and pistons or re ring the pistons that r in it and new bearings. I know it will be cheaper to get a new motor but I'd like to learn how to do all this
Edited by zac320
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6550524
Hey guys the local mechanic has convinced me to just put a new motor in. So I'm chasing a rb25 bottom end. No need for head or any other accessories. Just block to sump. It needs to be in good condition.
Cheaper the better especially if ur out of Vic as I'll have to freight it
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6553856
I have the bottom end here and I'm struggling to source a bottom end for cheap so. I'm thinking acid dip and hone block and clean up pistons and basic rebuild.
Bearings mains and rod $200
OEM rings $190
Nissan gasket kit $200
Rb26 rods $75 ( second hand from friend)
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6554057
I am going to do it. Took it to the Best local engine builder around and he doesn't want to do half the things, eg install rings on pistons but I install pistons. As he doesn't want to be liable if anything f**ks up. But he said I can take me engine into his workshop and do it there and ask for his advice which will be a great learning experience for me.
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6554109
im in your exact shoes.
it was option 1: buy 2nd hand unknown condition motor from someone.
or what i chose, option 2: rebuild, refresh and toughen up ("toughen up" being used lightly) my existing motor (ACL bearings, ross tuff harmonic balancer, crank oil drive thingo, ARP headstuds etc etc).
i think i would be kicking myself if i started getting huge blow-by after 12 months of getting a 2nd hand motor.
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6555672
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
