Hey guys I have 100000k stock block. Bent rods(hydrolock) I have found a really good deal on rb26 forged rods and cp pistons. They are stock 86mm size. Whats the possibility of the bore still being good? I've found a cheap rb26 crank to go with the rods and pistons aswell
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/
If the bores are fine then yes, normally you can just hone them and put standard sized (86mm) pistons in. You know 26 pistons will usually give you a lower compression ratio than standard 25 right?
It sounds like your best option could be simply sourcing a good complete stocker bottom end and throwing your head on it. Assuming you don't need a built motor?
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6550348
I thought if I go 26 crank aswell it won't?
Dnt need a built motor but it's either the forged rods and pistons or re ring the pistons that r in it and new bearings. I know it will be cheaper to get a new motor but I'd like to learn how to do all this
Edited by zac320
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6550524
Hey guys the local mechanic has convinced me to just put a new motor in. So I'm chasing a rb25 bottom end. No need for head or any other accessories. Just block to sump. It needs to be in good condition.
Cheaper the better especially if ur out of Vic as I'll have to freight it
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6553856
I have the bottom end here and I'm struggling to source a bottom end for cheap so. I'm thinking acid dip and hone block and clean up pistons and basic rebuild.
Bearings mains and rod $200
OEM rings $190
Nissan gasket kit $200
Rb26 rods $75 ( second hand from friend)
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6554057
I am going to do it. Took it to the Best local engine builder around and he doesn't want to do half the things, eg install rings on pistons but I install pistons. As he doesn't want to be liable if anything f**ks up. But he said I can take me engine into his workshop and do it there and ask for his advice which will be a great learning experience for me.
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6554109
im in your exact shoes.
it was option 1: buy 2nd hand unknown condition motor from someone.
or what i chose, option 2: rebuild, refresh and toughen up ("toughen up" being used lightly) my existing motor (ACL bearings, ross tuff harmonic balancer, crank oil drive thingo, ARP headstuds etc etc).
i think i would be kicking myself if i started getting huge blow-by after 12 months of getting a 2nd hand motor.
https://www.sau.com.au/forums/topic/410108-rb25-stock-bore/#findComment-6555672
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
