My r32 started spullerting as i drive now
It will drive fine then all of a sudden it will glug and then go and glug and then glug a sometimes stall
I have changed
Spark plugs
Fuel filter
Some coil packs as I had spares
Check all hoses
Took off my BOV and put stock back on
Still have it happening
Help! It doesn't seem electrical
https://www.sau.com.au/forums/topic/410136-weird-problems/
It was happening around the low rev range and was also happening alot when I am on slopes
Havnt driven it much since I have changed everything
I took It for a drive before and went up my street it glugged the whole way up and back down
https://www.sau.com.au/forums/topic/410136-weird-problems/#findComment-6550370
Only after the problem happened I didn't touch the car before hand
It's funny you say the ignitor
My car stalled and wouldn't start again a while ago and I decided to change the ignitor and it started straight up but was gluggy as it is now
Could that be ignitor as well?
Didn't think about buying a new one
https://www.sau.com.au/forums/topic/410136-weird-problems/#findComment-6554215
So many things it could be... A few to check/swap/test/clean
CAS
TPS
AFM
Fuel pump
Voltage to fuel pump
Hard to tell as "glug" could mean a lot of things, but if you try all these ^ plus what youve already done you should get somewhere.
Also make sure the spare bits you try are known working, not possibly working. Actually install them on or borrow them from a mates car that runs properly.
Good luck!
https://www.sau.com.au/forums/topic/410136-weird-problems/#findComment-6555717
Yeah I think it's something electrical
Could it be as simple as my battery?
AFM is fine as far as I know
I clean it every month as I change air filter every month
If its not electrical it has to be the fuel pump
https://www.sau.com.au/forums/topic/410136-weird-problems/#findComment-6556008
Its most probably the AFM, the contacts inside sometimes come loose and require resoldering. Do a search if you feel confident, or just replace it with a know good one.
Just looking at a component and seeing it is clean doesn't mean it is working.
https://www.sau.com.au/forums/topic/410136-weird-problems/#findComment-6556258
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
