Converting a 33 to a mac strut is not an easy task. The strut top mounting points are quite far in compared to a mac strut. If just slapped together, I would not be surprised if double digit negative camber was the result. Not only this, but the pivot angle on the strut top would likely be quite extreme over the full travel of the suspension. And on another note, (this next section is theory on my part, I may be quite wrong) the chassis was designed for suspension that directs most of its force vertically. If converted to a mac strut, the angle that it would be on would put a fair amount of force inwards. At a minimum, a strut brace would need to be fitted. Triangulating to the firewall would probably be advisable.
I believe the strut top mounting point is also too far forward to have any reasonable amount of positive caster.
There is one skyline I know of which has been modded to a mac strut. Have you ever heard the name Stewy Bryant? or Nisskid? When the biddies see him, they be froffin... ;)
This is his website: http://inertia-ms.com/
Have a poke around, you should be able to find a few pics of what he has done.
If you plan on having this car road registered, I suggest you stop now and rethink what you want to achieve.
But, if it's just a drift hack...angle grinder, welder, maths and common sense, you'll be swearing at it in no time.
The reason driftworks did it was for less weight and also more clearance when trying to achieve more lock (less arms etc in the way). Driftworks also used their special geo knuckles designed for S chassis which lowers the car 40mm I think without changing any suspension geometry.
  • 1 month later...
There is no good reason. None at all.
Well you've never added anything useful to this site, so why start now i guess eh?
Yes there is some unsprung weight savings with mac strut, but it's far from the reason why most people go down the path. For Drift one of the most important modifications to a car these days is the knuckle design, unfortunately for R chassis cars they decided to use a shitty cast item instead of the stronger and much lighter forged item the S chassis' use. More importantly than the weight to drifters is how much easier it is to cut and shut the knuckle while still keeping strength, as well as how much easier it is to change hubs etc, anyone who has had to change the hub on the front of a skyline frequently, quickly and with minimal tools knows exactly what i'm talking about, it's a head screw compared to dealing with the S chassis gear.
Clearance is also a bit of an issue with the R chassis front end at big lock, the sway bar links further out and the bulky upper arms can possibly create an issue with real large lock setups.
My biggest worry going away from the standard R chassis setup is simply strength, for a drift car, we use mostly the rear end to steer the car, the front end is more of a catalyst, so unlike grip cars which waste so much grip at each front wheel fighting both the rear end and in a lot of cases the other front tyre on the other side, drift cars are more efficient with the front grip they have and don't need to chase the same fractions of percentages of grip up front, so the geometry curves at the front are less critical, and the mac strut does a good enough job for most applications.
It's simplicity is a huge benefit, especially when you're not a race engineer or have access to a team of them, but most of all it's ability to make more lock easier is why the conversion has been done in quite a few R32's around the world, probably most famously the Bee*R R32 etc.
As far as my setup goes, there is very little that still resembles an S-chassis or R-chassis setup, however it does still use the S14 knuckle and strut, the lower control arms, tension rods and strut tower are all completely custom.
Charming. I was simply trying to dissuade someone (who is obviously new to all this) from committing wholesale butchery on their car for no good reason and without any proper engineering guidelines to go by. There are a raft of traps to fall into, strength and geometry issues for both the suspension components and the chassis being just the start.
Oh and by the way "grip cars" do not "waste grip". The whole purpose of the exercise is to generate and then use as much grip as can be found.
How did you come to the conclusion about so called Grip cars wasting energy "fighting" opposing wheels??
I'd assume or comes from the idea of locked diffs causing understeer.....
A sorted chassis has no such issues. The majority of the time its the driver not the chassis
lol sorry, i mixed you up with another SAU member who just comes in and talks shit unnecessarily constantly, it's been a while since i've been on here and the names are starting to mix together haha.
and yes, grip cars do waste grip, the rears fight each other around every corner with the diff resisting dissimilar radii, same as the front often depending on ackerman and scrub radius, although more importantly the front ultimately has to fight the rear and it's resistance to turn. All this is wasted grip, drifting wastes it's rear grip through spinning the rear tyres, however it uses it's front grip quite efficiently as doesn't have to fight the rear when turning, in fact the rear helps the front turn. This is why for sharp turns, where the radii differences are so great and there is so much conflict between every tyre on the car, drifting around the corner is often the fastest way, especially in low traction conditions (rally).
Your joking with you drifting around the corner is often the fastest way comment Arnt you??
Low grip gravel rally yes. Any thing circuit orientated your kidding yourself if you think drifting is the fastest way.
If a car is drifting its sacrificing forward propulsion to lateral slip and hence going slower than it potentially could.
Rally guys sacrifice this forward propulsion so they can go faster into a corner as they have more traction in a straight line, the longer they are straight the faster they can go. Due to the low grip they end up sideways, its a trade off for higher entry speed.
did i not just say that? lol
A good example was one time i was skidding in the hills, big rear grip, bugger all front, on a tight corner half way through the engine cut out (plug on the igniter module came off), the front just plowed as soon as the rear straightened, and off the edge i went. I was only able to make it through that corner with that speed under drifting conditions where i could use the rear grip to help steer the car, once i was left to grip up there wasn't enough front steer to keep me around the corner. This is an example of a poorly setup car, but the physics are still relevant.
Anyway this is off the topic, my point is that drift cars use the small amounts of front grip they have very efficiently, and therefore chasing huge grip at the front becomes less relevant, hence camber gain curves etc aren't as critical where the mac strut can some times fall down.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
