Hi all,
I'd like a little advice, I've currently got a set of Dunlop 03Gs in their soft compound but have gotten a puncture in one of the tyres.
I don't want to be racing with a repair job on them but I do have access to a set of 3 Dunlop 03Gs in their medium compound, one has low tread.
Would there be any issues in running a pair of the softs and a pair of the mediums?
I was thinking softs for the fronts and mediums for the rear.
The 2 sets of tyres are of the same width and diameter, 235/40/18. I race at winton with a jzx100 chaser.
Any help is appreciated.
Cheers,
Adam
absolutely no issues, people mix brands/compounds all the time, this is just a more extreme example.
obviously it will impact the balance of the car, but like you said soft front and medium rear is the way to go.
In My case they are different widths front to rear so the wider has to go on the rear for clearance...which happen to be the soft compound. Wont be the end of the world. The way I turn in early and have no grunt...lol I will probably overheat the fronts before the soft rears :)
I was thinking the exact same thing at one point there, Roy.
Around Winton I'd kill the fronts before the rears and having the mediums up front wouldn't be such a bad idea. My car tends to oversteer also on corner entry so softs out back personally wouldn't have been so bad.
I'm not going to find out either way, the other set of D03Gs sold so I decided to get a set of 33 GTR wheels and get new semis altogether..
Question now is what semis :P
Edited by adam-__-
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
