Hi guys,
Put this post up in general maintenance section and no replies as yet so I thought I'd ask some fellow sandgropers
I have just upgraded from a 33 GTST to a GTR and need to know how to adjust the grab point of the clutch as it is almost at the top of the clutch pedal throw
I did this on my GTST but this looks totally different
Can someone help as I have never worked on a GTR before
Cheers
https://www.sau.com.au/forums/topic/410144-r33-gtr-clutch-adjustment/
Should be the same on a GTST, Just "unlock" the 14mm nut and adjust the rod accordingly?
LOL " Should be the same " GTR run a clutch booster and is not wise to adjust the rod , adjusting the pedal will just screw things over . Let the people who know offer the advice ..
The "same" in the sense they run the same type of rod/adjustment system regardless of having a booster or not.
In regards to the adjustment anyone who has fitted an after market clutch (say a twin plate) would have adjusted this rod to get the correct pedal adjustment. Just be carefull when adjusting. You always need about 2-3mm freeplay.
No free play will lead to excessive clutch wear, and too much will lead to a high grab point.
Oh an working on vehicles 5 days a week for almost 7 years, I think I have the "know" to give out this kind of advice :)
Edited by marksuxass
So you adjust the pedal side of a boosted clutch and nothing else ?
I tried but failed in adjusting clutch
On my GTST there is a 12mm lock nut and a post to screw in/out
On the GTR the setup is the same but the post is covered by a rubber grommet all the way from the locknut to the firewall.
I tried to pull the grommet back but it doesn't look like it should be messed with.
There is also a pedal adjustment that doesn't effect grab point just gives you a longer or shorter maximum throw of the pedal
HELP
Anyone ???
Does this mean there is no adjustment and my clutch is worn?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
