Hi guys
Would appreciate any help to replace my driving fog lights / high beam. Well im intending to put HID on both high beam and low beam. I know for sure that Low beam uses D2R and high beam uses H4 (dual filament for fog light as well). well my question is there are 4 types of H4, H4-1,2,3,4. which one should be picked for our cars ? Im pretty sure it wont be H4-4 coz the current bulb doesnt seem to be a twin bulb type, and it should not be h4-1 either. Regardless, im pretty confused and deseprately needs u guys to help T_T
https://www.sau.com.au/forums/topic/410153-help-on-drivingfog-bulb-replacement/
Your highbeam/fog lamp as they use a single normal H4 halogen lamp. You will need a H4 HID replacement to convert this to HID, similar to the H4-3 unit listed here -
http://www.hid-lightsdownunder.com/service1.html
If you have D2R lamps in your low beam, they are already HIDs. - the low beam is a totally separate lamp in a totally separate reflector.
From what I understand H4-1 is a low beam only lamp (fog light only). H4-3 uses a single lamp with a retractable light shield. H4-4 uses a twin lamp.
  • 1 month later...
my drivers side "top" light has gone out, i beleive the bottom circular shaped bulbs are the fogs/low beam is that correct and the top lights are the low beam/high beam? Don't know what to replace the bulb with, i know it's halogen but not sure exactly what typre of bulb to replace it with.
well, "top" is low beam ONLY...the lower part is high beam/ fog (driving lights actually) ... HB2 (9003) is the one for that high beam / fog light (aftermarket projector however uses H4 instead.) and D2R is the one for ur "top" light which is LOW BEAM ONLY
Sedan was the only model that ran a dual filament bulb for high beam / driving light.
Coupe' ran a H1 bulb for high beam as driving lights were an option that went into inserts in the front bar.
Low beam on both is D2R, unless converted to Halogen then it will be a H1 globe and a little insert fitted to the globe holder.
mate, i run a coupe :), 04 model (not sure if that makes the difference) but i have "driving lights" and "high beam" in the same bulb. because i can turn on driving lights and flash, i can tell the height changing so definitely that must be a dual filament type :)...not sure other models though :)
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
