Hi guys
Would appreciate any help to replace my driving fog lights / high beam. Well im intending to put HID on both high beam and low beam. I know for sure that Low beam uses D2R and high beam uses H4 (dual filament for fog light as well). well my question is there are 4 types of H4, H4-1,2,3,4. which one should be picked for our cars ? Im pretty sure it wont be H4-4 coz the current bulb doesnt seem to be a twin bulb type, and it should not be h4-1 either. Regardless, im pretty confused and deseprately needs u guys to help T_T
https://www.sau.com.au/forums/topic/410153-help-on-drivingfog-bulb-replacement/
Your highbeam/fog lamp as they use a single normal H4 halogen lamp. You will need a H4 HID replacement to convert this to HID, similar to the H4-3 unit listed here -
http://www.hid-lightsdownunder.com/service1.html
If you have D2R lamps in your low beam, they are already HIDs. - the low beam is a totally separate lamp in a totally separate reflector.
From what I understand H4-1 is a low beam only lamp (fog light only). H4-3 uses a single lamp with a retractable light shield. H4-4 uses a twin lamp.
  • 1 month later...
my drivers side "top" light has gone out, i beleive the bottom circular shaped bulbs are the fogs/low beam is that correct and the top lights are the low beam/high beam? Don't know what to replace the bulb with, i know it's halogen but not sure exactly what typre of bulb to replace it with.
well, "top" is low beam ONLY...the lower part is high beam/ fog (driving lights actually) ... HB2 (9003) is the one for that high beam / fog light (aftermarket projector however uses H4 instead.) and D2R is the one for ur "top" light which is LOW BEAM ONLY
Sedan was the only model that ran a dual filament bulb for high beam / driving light.
Coupe' ran a H1 bulb for high beam as driving lights were an option that went into inserts in the front bar.
Low beam on both is D2R, unless converted to Halogen then it will be a H1 globe and a little insert fitted to the globe holder.
mate, i run a coupe :), 04 model (not sure if that makes the difference) but i have "driving lights" and "high beam" in the same bulb. because i can turn on driving lights and flash, i can tell the height changing so definitely that must be a dual filament type :)...not sure other models though :)
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
