External Wastegate On Stock Exhaust Manifold
Just in case anyone is interested in doing this mod. I know it's a popular mod and works quite well.
1 - select location, preferably located in the middle of the merge to the exhaust housing and on an angle to make the air entering the wastegate as strealine as possible
2 - die grind the hell out of the standard exhaust manifold until you get rid of the scaley crap on top. Go at least 10mm past where you are going to weld the flange to the manifold
3 - either holesaw or oxy the hole and clean it up with the die grinder, get ready to demolish on carbide tip, they dont like the cast steel. Being a splut pulse exhaust housing, I first drill the hole with the hole saw and since I dont own an oxy, cranked the tig up and blasted the inside of it away. Again, the die grinder came in handy to clean it all up at the end
4 - No just place 3 or 4 tacks around the 'gate flange and weld. did not preheat it at all. Ran 1 root pass and 2 filler passes. One think to keep in mind it is to be slow on the downslope. In my experience, the cast steel doesnt like cooling down quickly, so aim for 1.5-2 downslope.
I used around 90 amps on the root pass, and less on each subsequent pass.
Here is the end result
If anyone has any questions, just let me know
Good luck, let me know if you need any advise.
Sorry no pics of it back on the engine since the manifold was just bought to me and that's it, but there is plenty of space to the strut tower so no hassles there
  • 1 month later...
hey champ im keen to do this one my rb26 i was wondering what it would cost to get you to duplicate those manifolds?
the question has to be asked here!! why? the manifolds are seperate so will need 2 gates unless you some how mate the gate ports together and run one?
The purpose of doing this is to improve top end power. Bridging the two into 1 gate just defeat the purpose of the exercise.
Btw what are the largest external gate turbos can u fit with these modified manifolds?
Edited by 9krpm
Sorry I'm new to all this, but I have a r34 high flowed turbo by gcg, it has been modified to suit external gate,
Do I need a actuator?
I want to modify my standard manifold for the gate, I'm in Sydney is there anybody I can get to do the fabrication work?
you just need to buy an external gate and get it fabbed to the standard manifold :) most workshops will do it for you
  • 2 months later...
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
    • Righto,  enough of ADHD Anonymous! 🤣🤣 Rear end is completely stripped out apart from coil overs that will take 5 minutes.  Fingers crossed it doesn't look like that for too long!   Cleaning up some bits as I go so they can go straight back on. It amazes me how good stuff looks just with a good hard scrub! That will be it for a couple of weeks. I've got ot a bit of surgery Friday that will put me out of action for a few weeks. Hopefully the motivation is still there when I'm ready to get back into it!
    • The povo spec CA18S one, yeah. All turbos had 16x6.5 5 stud and 4pot brakes.
