Up for sale is my pride and joy 93 R33 GTsT skyline. I am the first Australian owner of this vehicle and have owned it for the last 6 years. I purchased this vehicle completely stock and have slowly upgraded it over time with tasteful modifications while still maintaining its great driveability and reliability. All major modifications, tuning and service work has been carried out by Gavin Wood at Autoteck, and always using genuine Nissan parts. The car is serviced every 5k and is run only on 98 octane. The gearbox and diff run Redline oils. The car is also fitted with a 3 stage immobiliser and alarm.
The car is currently 214RWKW, and the list of modifications is as follows:
Apexi high flow panel filter.
GReddy front mount intercooler kit, including washer overflow bottle.
JJR 3" split front dump pipe
3" X-force high flow cat
3" X-force cat back exhaust system
Turbosmart bleed valve boost controller
High flow 740cc injectors
Walbro fuel pump
Apexi Power FC ECU
Yellow Jacket coil packs
NGK platinum plugs
Excedy extra, extra heavy duty cushioned button clutch, (less than 5000klms old)
Oil catch can with breather
New radiator hoses
Nismo oil filler cap
Turbo timer
Pioneer I pod head unit
Spit fire boost guage
New leather gear stick and hand brake boots (black with red stitching)
D-wing rear spoiler
20% tinted windows
Wheels: Yokahama AVS6 Front:18x8.5 Rear:18x10
Tyes: 80% tread Nangkang Ultra Sport NS2 Front:235/40r18 Rear: 255/35/r18
RWC will be provided upon sale, buyer to supply own rego. Price is $11500 ono
post-34657-0-02556600-1348576395_thumb.jpgpost-34657-0-58916700-1348576405_thumb.jpgpost-34657-0-13304600-1348576432_thumb.jpgpost-34657-0-19181100-1348576449_thumb.jpgpost-34657-0-59975000-1348576474_thumb.jpgpost-34657-0-58159200-1348576544_thumb.jpg
https://www.sau.com.au/forums/topic/410176-214rwkw-r33-gtst-for-sale-11500/
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 3 months later...
*******UPDATE PRICE DROP! $9500, CAR NOW HAS RWC AND WILL BE SOLD WITH 6 MONTHS REGO********also car's rear wheel bearings are starting to get noisy, I am happy to retify this for the sale price or reduce it to $9000 as is.
  • 4 weeks later...
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
