In Tank Lift Pump To Support 6-800 Rwhp
Kierin
 Share
Hey Guys and Girls
In the market for an in-tank lift pump that can support approximately 6-800 RWHP (C34). Car will not make it straight up but I like to avoid doing things twice. Already have an out of tank setup with surge tank using Bosch 044's. A supplier of proposed pumps would help so that I can purchase it quickly.
Sorry for not researching this thoroughly myself, I only have a short period of time to look online when away for weeks at a time for work.
Thanks in advance, Kierin
Pretty sure this would suffice ..the lift pump is not working against turbo pressure and will easily deliver enough fuel to the surge tank:
http://www.trademe.co.nz/motors/car-parts-accessories/performance/fuel-systems/auction-516957124.htm
here is the other one if you prefer:
http://www.trademe.co.nz/motors/car-parts-accessories/performance/fuel-systems/auction-517719331.htm
I'm putting a DW200 on the shopping list, I keep thinking about the day the stock pump will fail.
Yep its better to replace it at a time of your choosing rather than have it fail on a rainy day miles from home so you have to add the price of a tow truck to the job.
Ive just installed a walbro 340lph as a lift pump to surgetank but have ethanol sensor in the return line back to main tank which only flows 200lph
Is there a problem with slightly pressurising the surgetank at idle? .. will fine open throttle ?
The ethanol sensor should be on the return line from the rail, as close to the last injector as possible. Otherwise you may have issues when you swap fuels and they haven't mixed properly.
A small amount of pressure in the surge tank shouldn't give you dramas, how did you measure the sensor flow? I was worried it wouldn't flow enough...
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
