Hey guys,
I have a rb26/30 with all the goodies in it, I am wanting to run 35+psi on E85 and i have been told that the ignition has to be changed to do so. Can you big hp guys recommend a setup to run as i am chasing 750rwhp through my glide. cheers
https://www.sau.com.au/forums/topic/410235-rb2630-ignition-setup-help/
http://www.aemelectronics.com/high-output-igbt-inductive-smart-coil-1240
This is what I would use - best inductive ignition system I've seen.
I tend to prefer running inductive ignition system compared to cdi on almost all applications - especially on street cars.
They look like awesome coils. No CDI or igniter unit required. Less to go wrong?
How have they performed for you rob?
Why do you not like CDI systems? Because of the electrical interferance and low dwell time?
I'm about to turn up the wick on a certain engine that will be in the vacinity of 2000hp with these coils - currently at 1260hp and no issues with 1.1mm at 18psi. Have seen them not misfire with 1.1mm gap at this boost with mixtures as rich as lambda 0.67.
CDI is good if you want high peak secondary current and minimal dwell time - issues I have with CDI is eletrcial interference and low spark duration coupled with extra cost. Only thing with these coils and LS2 series coils is the dwell time can be as large as 5ms at 14V for full spark energy which can be a bit much on non sequential setups with rapid accelleration rates and flat shifting. Doubt most people would run into this issue though.
Edited by rob82
Isn't it easier to ignite the air/fuel on an engine that has a much larger bore like that one?
http://www.aemelectr...smart-coil-1240
Certainly look like great value for money - any potential downside?
Yep - generally the higher the torque the greater the cylinder pressures so the higher harder it is on the ignition system...
I haven't try these coils on an xr6t, because they wouldn't fit very well but the are probably one car that really pushes a coils ability and I know just the car to test on. If I get to test them on that car I will let you guys know how they hold up?
Also the only other downside is that they aren't cop...
Edited by rob82
We have run these coils on a 140mph 1jz running nos for the last 12 months.
Very good coil charge time with amp saturation. Would I run them on 50+psi probably not.
That's not to say that they wouldn't do it, I would not like to commit and say they will and then have to fit CDI any way.
I have found that inductive just seems to run nicer with back to back tests. Engines just sound that little bit happier.
Everyone likes a happy engine don't they
Well at the end of the day, after cylinder pressure and temp, Egts, MBT, BSFC, gudgeon pin size, exhaust wheel temp, oil pressure and temperature all we are doing in pleasuring the engine just how it likes it.
Golden rule, give the engine what it wants. If it wants CDI it gets CDI. If it want 28 degrees of ignition timing at 30psi of boost and a 175 shot of gas then give it 28 degrees.
Its kinda like an extremely high maintenance gf. You work and work for months just to be able to take it out and show it off to your friends then it craps in your face just to keep you keen (Or on the highway at the top of 4th gear) when it doesn't get its way.
The only downfall i can see with these is they are a damn big coil. Mounting 6 of these may not be the easiest to do so.
But i do like, and these have risen to the No 1 on my most likely coil to buy for my setup.
So these would be worth a try on my RB30/25 aiming at 330 - 350 awkw with a rev limit of 6800 and no flat shifting or would I need to change my Link G4 with 4 ignition channels for a Link Extreme to allow sequential firing?
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
