Cas Noisy (23731-5L300)
bentwagon
 Share
Start the engine, grab a hose and lightly start spraying water on and around all belts/pullies and see if noise changes/stops.
Finally managed to do this the other day - noise stops for a second then continues.
Quick q - does the cas on a series 2 require the cas seal?
kind of, in the seal are 3 brass standoffs, they space the cas out the correct distance to stop you loading up the thing and breaking it
When the noise stopped for a second, where were you squirting the water ?
Edited by Jezboosted
With engine off see if you can twist a A/C, PS or Alt belt more than 90degress with one hand. If you can, tighten it up. It May also be too tight and back off a touch if necessary.
Can you isolate it to a single belt perhaps ? Using a glass of water just slowly dribble it onto 1 belt and listen for change. If no change, move to next belt.
So, took it to the mechanic - needed brakes done - and they said the noise may be power steering needing a flush, either that or its the pump. Tightened belts a little but noise still there. Now to research how to DIY power steer flush...
Have you tried yet what I mentioned earlier about narrowing down which belt made the noise ? Get a plastic drink bottle and drill a small hole in the lid. Just do one belt/ pulley at a time and wait 20 seconds before trying next belt. You know the sound went away when you hosed the belts. How can this then be caused by PS fluid ? ones internal, the other is external.
Did you twist the belts and see how far they twisted ?
 Share
    • You've given zero info about your setup. Step 1: make sure all the standard equipment are working as they should. If they're not, go investigate why. Step 2: Make sure all your wiring is done properly. Know which RB20 you have, most likely "silvertop" a.k.a R32/A31 anything after 1989. Step 3: make sure your ECU is tuned properly. Standard will barely run in this situation.
    • Depending on your use case, prop valve will almost always be a better choice.
    • I think... in the US, Silvermax is the equivalent of BC Racing, i.e. cheap Taiwanese built suspension that gets turned for "local" conditions. Back in the day in Australia, you could get MCA street for about $1300 and they were awesome. Don't know about now... In saying that, my real world TEIN experience: I got some street basis z for my old Liberty (BR9), and they were awesome ($800-odd delivered from demon-tweeks in the UK). so Don't discount TEIN
    • yeah my RedBull X2010 on Grand Valley is only good enough for bronze... I can't hit silver arrgh.
    • 100% this. Long ago, I had a guy from the R31 club who set my BNR32 up (adjustable arms all round). He did an awesome job, was an after-work kinda thing where I had to bring a slab of beer. My car never drove better, and I stupidly got a random tyre shop to check the toe angles when I changed tyres, and they ruined the alignment. tl:dr- it takes a lot of skill to set up your car lowered from factory properly, and is worth paying the $200+ it takes.
