I've done three of them and they've always bolted straight up, oil and water lines all match up fine. Try find one with the compressor elbow that has the vacuum nipple coming off it factory, I'm fairly sure they come off the R34 turbos
what do you mean no power gain?
RB25 turbo at the same boost the RB20 turbo was set to will produce a fair bit more power.
remember to use the actuator from the RB20 turbo on the RB25 turbo
that way you get 10psi stock instead of the 7psi the RB25 actuator holds.
many years ago, I put a series 1 R33 turbo on an RB20.
with 10.5psi and no tune it made 152rwkw
Also, R33 and R34 turbos are not the same.
R34 turbo has a bigger rear and will be laggier on teh RB20.
Stick to R33 turbo.
just go to an exhaust place, tell them to remove the intercooler piping that goes from the turbo tot he cooler, and tap a nipple to the pipe as close to the turbo as they can.
that is where the vacuum line from the actuator will go.
The one i drive was laggy with the 33 turbo on the RB20 anyway, pretty stock sort of setup.... Not sure if its an RB20 thing or due to the bigger turbo?
If its an original a31 rb20det, the water lines have a different (smaller) banjo bolt. can't remember size, m16 (a31) instead of m18( r32, r33) maybe.
Got caught out when I did this on my first cefiro.
So you can get water lines off a r32 rb20, they will work, or make up custom water feed/return lines.
And yeah, you'll see some gains. worthwhile mod if you need to replace turbo anyway.
Edited by CEF33Y
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
