Hi guys,
Okay I got a pod filter,
racing radiator
hd clutch
3" full turbo back exhaust+ high flow cat
boost up to 12psi
Currently getting better coil packs to fix miss fire problem
what should i do next?
Fuel pump?
Injectors?
Chip and tune?
looking at $1500 to $2000 budget
What you think guys??
Fuel pump, Nistune fitted and properly tuned.
This^^ Include filters and oil changes and new plugs as well if you already haven't done so...
Good preventive maintenance goes a long way
What happens when he can't get 100ron or E85??
If its tuned not on the edge then he should be fine to use 98 but not be flogging it, hows that different to not being able to find 98 and having to put 91 in, you just dont be flogging it , common sense
When can't you find 98?
I've never not found 98, and I've been through that many bush whacker towns with the GTR..
Would be silly to have it tuned on anything but 98 in this situation
good point, what i mean is a few octane points drop shouldnt be an issue in the rare case you cant get 100 or some eflex, if its not a daily and you want every last kw then it would help.. and most people are looking for every kw they can get for cheap..as long as it still practical for them i guess, but 98 would be less fuss.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
