You shaw ? I have one for 2kw less :)
Yeah I know rub it in
Everyone has one pump except me
For some reason 4 door needed a super setup
I guess it's thirsty work carrying this fat ass around on boost
  • Replies 321
Posted Images
Poor excuse, my single pump hauls my fat ass around :P well actually it doesn't as I never drive the kent!
Hey guys,does any one know of pet friendly accomodation in the hunter,
love my lil doggy and can't travel with out her. :cheers:
Not off hand but can help look if you like?
Cheers mat much appreciated,really hard to find some where affordable in the hunter. :D
Also, post in the Newcastle thread as well in case the others know any? Better off on the outskirts of the Hunter to keep $ down
My family have place in hunter http://www.rothburyescape.com.au/ they have a dog , say Aaron asked if ok im sure it would be fine .
Oh and Kurtis maybe its the exrta 30cm of fuel lines ? or your tuna :)
foshizzle. I shouldnt be away for work so Im coming on le cruise
Sweet! So every car will have an NPC clutch by the end of the cruise? :P haha
HAHA, Ill get some NPC stickers printed oh and flyers. haha,
can I bring a guy with a evo?
Yeah of course you can man.... Just let me know which meet point etc and I'll add both cars to the list ;)
No need for an NPC sticker for me :ph34r:
Cheers Aaron will check it out. :D
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
