As a part of pro fabrication I've now got an employee doing all of our Motorsport wiring looms in house.
Using high end Materials we have begun putting together drop in harness' for Nissan models that would be in demand.
The S chassis is one such vehicle but of more interest is the GTR.
These are bare essential looms and so far we have decided to include.
Attessa control unit & outputs to ecu
Provisions for ABS to be operational
All front and rear lights operational
circuit breaker unit (no fuse boxes)
Factory indicator stalk
Lights etc on switch pannel
3x fuel pump power feeds to boot
Blower fan or heated screen power
Thermo fan supply
Ignition key
And a couple of other small incidentals.
I'd like input from people interested in these as to what other things they'd like to see either fully wired or atleast provisions provided within to harness.
Things like electric steering pumps etc
We are using deutsch connectors exclusively and supplying the harness with a "mill spec" connection on the fire wall or grommet for the budget conscious, no cheap conduit cover either, everything is done using tech flex braid and sealed with shink tube at the ends.
the 3 skylines, 1 s15 and lotus exige that have been done have all been very affordable as far as custom professional wiring looms go.
Interested. Running an Apexi Djetro but will soonish change this... however the car is going well and I have tweaked it a bit.... anyway enough rambling. i was going to change the complete loom anyway for a NOS loom. So interested and will buy in the next month or so.
Edit - just realised you not talking about ecu loom. Sorry, interested in ecu loom made out of tefzel/braid.
Edited by LWO
We have done a number of custom GTR engine looms recently to suit specific requirements.
Tefzel and tech flex braid with deutsch connectors is not a problem. Raychem shrink can be used if the budget permits.
Yes we can do a tefzel ingnition lead with austere deutsch plug and oem coil plugs
Can you let me know a price sent to Christchurch, NZ please for a R32 GT-R one.(Not sure if they differ between models)
Edited by Sub Boy32
Your looking at $330aud for a complete coil pack loom supplied with new Nissan plugs, braided wiring protection and deutsch connectors for the power and ground supply.
(you will just need to cut the Nissan plug off your cars look and solder the deutsch pins on for the power/ground plug)
  • 2 months later...
Did this go ahead futher, and what was the approximate price?
Some other things worth allowing for:
  • Accessory power for rally safe/terra trip/camera power supply.
  • Seperate circuit, battery, wiring for intercom (no interferance)
  • Seperate circuits for everything to ensure one dead one doesn't kill others.
  • Power for boost controller, power steering, dash/gauges, lap timer
  • Horn circuit, power windows, heated screen required for rally cars
  • Fuel level sender and warning light
Sounds like you need to drop your nugget off for a rewire Duncan.
Actually I've seen the looms in your car and it could do with a freshen up.
Engine looms start at $660 and can go up to $1500 for one with the works. That's using detusch connectors and quality wire/braided sheath.
Full looms for the skyline start at $1500 and can run up to 3k for something like a motec/awd install.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
