Saul Posted September 28, 2012 Share Posted September 28, 2012 The indicators work fine but the clicking noise stays on. The flasher unit finally stopped working, i replaced it with a new genuine one but it still clicks when the indicators are off. Link to comment https://www.sau.com.au/forums/topic/410383-r33-s1-indicator-problem/ Share on other sites More sharing options...
t_revz Posted September 28, 2012 Share Posted September 28, 2012 I've had this happen too but Rh indicator occasionally was on dull. Remove covers around steering column. Undo 2 plugs to indicator stalk. If it stops then it should be a faulty switch. If not its a wiring fault. Undo 2 screws holding stalk to coloumn. There is a plastic cover that covers everything. Just have to pry it off while lifting the clips at the same time. Inside is 3 contactors for indicators and hi-beam. Mine were heavily greased but had heaps of dust n crap caught in the grease that was causing it to contact poorly and come on by itself. Clean it up and before putting it back together double check the indicator auto-off pin is still on the right spot. Pop cover back on and test it Link to comment https://www.sau.com.au/forums/topic/410383-r33-s1-indicator-problem/#findComment-6555847 Share on other sites More sharing options...
Got a Pulsar Posted September 28, 2012 Share Posted September 28, 2012 Similarly, I had an issue with my 94 Bluebird with the indicators coming on by themselves or not stopping properly. After a few weeks, a puff of smelly electrical smoke came out of the switch area, so I decided to check it out. Pulled all of the above apart (very similar) and found a small bit of plastic had melted away between 2 contacts. I looped a fine cable tie in between and superglued it in place, trimmed off the ends and never had the issue again. Link to comment https://www.sau.com.au/forums/topic/410383-r33-s1-indicator-problem/#findComment-6555861 Share on other sites More sharing options...
buzz350 Posted October 2, 2012 Share Posted October 2, 2012 replace the stalk, had mine do that, in the end it shorted out on both sides a lot of blue electrical smoke and well yeah ran late for tafe that day. once the stalk was replaced had no troubles since. Link to comment https://www.sau.com.au/forums/topic/410383-r33-s1-indicator-problem/#findComment-6559915 Share on other sites More sharing options...
mad082 Posted October 3, 2012 Share Posted October 3, 2012 i had the ticking noise from the indicator stalk constantly going in my vt commodore. the indicators would only work when the stalk was moved, but the clicking would come and go, such as if i hit a bump it would go crazy. new stalk fixed it Link to comment https://www.sau.com.au/forums/topic/410383-r33-s1-indicator-problem/#findComment-6561626 Share on other sites More sharing options...
