Bought this car in February 2012 after returning back from overseas work commitments. I spent over 2 months trying to find a decent platform for a car but realized that finding a decent one is pretty hard considering even the late model R32 GTR's will be turning 20 years old very soon. I have always wanted one ever since i was kid after I saw there domination in both GRP A touring car racing in Australia and overseas.
I didnt want a HI PO skyline or a purpose built track car ( I have a datsun 1200 coupe for that) but something that i could use for a nice weekend cruiser that would be quick enough to keep other cars honest but also be nice enough to drive around smoothly. I didnt want to drive around a defect magnet either so i went for something subtle and standard looking.
I finally settled on this particular example because it was very straight and mechanically seemed very good. It still had a half page list of stuff to do when I bought it but i managed to knock off a considerable amount off the original asking price, sure enough i picked it up and took it home and begun work.
The guy couldn't tell me much about the car or what had been done to it. So I had a detailed look and worked out that this was what it had,
Suspension and Brakes:
- BC Coilovers
- Front and rear white line adjustable sway bars
- Nolathane bushes throughout
- Adjustable control arms and tie rods.
- Front and rear strut braces
- Brake master cylinder brace.
- Standard brake calipers and rotors setup.
Driveline and wheels:
- Standard diffs and gearbox.
- 19 X 10 inch deep dish white ALLSTAR mags.
Engine:
- Apexi power computer with hand controller
- Standard airbox setup with K and N filter
- Tomei poncams (unsure of profile)
- Engine internals unknown.
- Turbocharger's, Intercooler, inlet manifold and fuel system all appear standard. (Keyword appear)
- 3 inch exhaust mandrel bent with Hi flow Cat from behind dump pipes, dump pipes are still standard at this stage.
The repair list was this:
- ABS 4WD LIGHT staying on.
- Water hoses need replacement under inlet manifold
- aluminium radiator had no shroud on it so clutch fan cooling was redundant.
- front brakes needed attention
- drivers side door trim needed re-gluing
- A/C needs regas or repair
- Transfer case gasket leaking
- Full service and all fluids needed replacing due to the car sitting still for so long.
- Front guards had a very small amount of rust in them bottom of the sill.
- Wheel spacers needed removing and 19X10 inch wheels needed to be replaced for something a bit smaller and she needed a wheel alignment.
- needed rego and insurance
https://www.sau.com.au/forums/topic/410420-my-1993-r32-gtr-restoration-project/
  • 4 months later...
car still needs A/C system and windscreen washer jets fixed. Quoted $1200 to retro fit new R134A compressor and regas system and I was Quoted $500 to pull dash apart and fix suspect switch. Overall the car is running beautifully at the moment im just not so keen to keep using it as a daily. Will probably have to wait till tax time to fix the above problems.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
