  • 4 weeks later...
Here are my only 2 RB26 engine i've ever built, The gold RB26 was a N1 NUR Spec engine produced approx 550-600HP out of my R33 GTR (now sold) and the other is out of my R32 GTR N1 8sec Drag car Jun/Tomei RB26.5 produces 1000HP +. Here are the Before and After Pics:
R33 GTR Before:
R33 GTR After:
R32 GTR Before:
R32 GTR After $$$$$:
love it
RB25DET TD06-20g 300rwkw @ 17psi (back in early 06)
RB25DETT (twin T3/T4 turbos, 399rwkw @ 17psi. Nov. 06)
25/30 (twin t3/t4s. March 08)
25/30 (garrett T51r. December 08)
26/30 (garrett T51r. July 11)
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
