Or more to the
True, but... more to the point, what's important is that the RB25 gearbox wasn't from a Neo. The engine doesn't matter, but the Neo gearbox is different.
In my case, I have a Neo engine, 33 box, 20 clutch.
He didn't say there wasn't a Neo with a Neo gearbox in the car before it was pulled out.
I understand what you are saying but specifically what I meant was: If he pulled out his Neo Rb25 with Neo gearbox attached and thought 'shit, that clutch was new, I should put it in this 20 I'm gonna put back in here', then he needs to know it won't fit.
Sorry to complicate the topic. Just trying to be thorough in light of the lack of information provided
https://www.sau.com.au/forums/topic/410456-rb25det-clutch/#findComment-6557686
Sorry for the Hi-Jack.
Does this mean the R34GTT Gearbox does not bolt onto the R25DET?
https://www.sau.com.au/forums/topic/410456-rb25det-clutch/#findComment-6564290
The gearbox will bolt on no problem. Just the clutch is pull type so you would need to swap the bell housing with a push type to use a push type clutch or convert it......or use the R34 clutch with it
https://www.sau.com.au/forums/topic/410456-rb25det-clutch/#findComment-6564373
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
    • Righto,  enough of ADHD Anonymous! 🤣🤣 Rear end is completely stripped out apart from coil overs that will take 5 minutes.  Fingers crossed it doesn't look like that for too long!   Cleaning up some bits as I go so they can go straight back on. It amazes me how good stuff looks just with a good hard scrub! That will be it for a couple of weeks. I've got ot a bit of surgery Friday that will put me out of action for a few weeks. Hopefully the motivation is still there when I'm ready to get back into it!
    • The povo spec CA18S one, yeah. All turbos had 16x6.5 5 stud and 4pot brakes.
