i dnt really know lot about cars just owend my first r33 might be a stupid question but as i sayd dnt kno much so
my clutch is gone now im goin to upgrade it to a racin stage 2
ill run about 700hp and is a daily drivin but weekend it drift alot and dragrace
i know they told mi act stage 2 wil do fine but i get these stage 2 6 puk disk or srupng 4 puk disk idk what s the benefit or dowside of these puk or no sprung or srpung 6 or 4 puk so if some1 could help mi or explain to mi whats the downside or benefits between these
https://www.sau.com.au/forums/topic/410509-upgrading-clutch-on-r33/
  • Replies 70
Mr NPC here. haha damn you mat.
For such a high power application you should be looking at some strong twin plate.
is this 700hp at the treads or 700bhp?
Anywho contact NPC (who saw that coming?)
Oi mat, how is the jim berry? I havent seen any posts about it...
I always feel a bit sad when people are buying "stage 2" etc parts
It isn't need for speed, no idea why people market parts like this
Because for 60-70% of people who come from something different, think that is the norm and from a marketing perspective, it works fairly well.
Also remember that 80% of statistics are made up and shouldn't always be taken as gospel but 50% of the time, it's right every time
60% of the time, it works every time?
What kind of cash money are we talking with NPC clutches for something around 400-500bhp? I've just done my HD clutch in the skyline at 220rwkw only 10,000kms old, one day after I got it back from the tuners. Haven't had much luck with cars lately.
ok so ill would need to be looking at nismo or npc 4puk sprong kits ?
material wise ??
im askin cause dnt realy have knowledge in this area
Ring NPC tomorrow on 07 3277 9403 and Doug will be able to talk you through whatever your needs are. They can custom build any clutch to your requirements and as long as you're honest about what you are going to do to it, it will never fail until its old
material wise ??
have you driven a 4puck clutch before? with 400hp the organic might be better for stop/go daily driving
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
